04-20-2008, 01:09 AM   #1
Trouble with macro
I have a Tamron 70/300 on a pentax K100 D I can not seem to get it to focus in macro mode can advice me were Im going wrong please.
04-20-2008, 01:21 AM   #2
Bramela's Avatar
Hi
Are you switching the Macro switch on the lens. This switch can only be operated when the lens is set 180mm or greater.
You should find this will put it right for you. The telephoto ring can be found to be a little difficult to turn manually to set the lens to 180mm ++.
Hope this helps.
04-20-2008, 01:43 AM   #3
QuoteOriginally posted by Bramela Quote
Hi
Hope this helps.
Thanks Bramlela, yes I have the setting on the lense set to macro but when I try to focus the lense just zooms in and out and does not focus to the subject.
04-20-2008, 06:04 AM   #4
Lowell Goudge's Avatar
most lenses that have a macro switch, like my vivitar S1 70-210 F3.7 change the way they work when in macro mode, focusing is very limited in function, and the zoom function becomes the way to focus.
Note you usually have a restricted range of focus in this mode between a few inches and a few feet, but this should be in the documentation.
04-20-2008, 07:32 AM   #5
roy
roy's Avatar
forget about AF. put the lens in macro mode and focus to infinity and move the cam in and out till you get focus. you should be about 3' away from the subject at 300mm
04-20-2008, 08:22 AM   #6
macro
Cheers guys for the help my fault had the lens set to macro but not the camera what a dope.
04-20-2008, 09:11 AM   #7
pentagor's Avatar
QuoteOriginally posted by philstaff Quote
What do you mean with that?
04-20-2008, 09:16 AM   #8
jsherman999's Avatar
Interesting. Using the "macro" setting on the dial apparently fixed whatever the problem was? What was the dial set at before?
04-20-2008, 10:49 AM   #9
The camera was set as I left it in manual mode from previous shoot, once I had set it to macro mode then the lens was fine.
k-mount, macro, pentax lens, slr lens
Having trouble with Diafine. Swift1 Film Processing, Scanning, and Darkroom 13 08-24-2010 02:58 AM
Sigma 70 macro trouble OrenMc Pentax SLR Lens Discussion 6 09-04-2009 09:07 AM
Is Pentax in trouble? I think so! jack56 Pentax News and Rumors 55 08-13-2009 12:42 AM
Sunblitz 6000i Macro Ring Flash and a Pentax... equals asking for trouble? Syb Flashes, Lighting, and Studio 3 12-14-2008 11:13 AM
So am I in trouble Eastern Shore Charlie Post Your Photos! 8 10-24-2008 08:46 AM
All times are GMT -7. The time now is 05:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
