03-26-2014, 01:39 PM   #1
Macro or Wide Angle first?
So I'm for sure buying a new lens within the next month and a half, problem is is I am very undecided on which lens to purchase! I am very interested in both landscape photography, and close-up photography - portrait capabilities would also be a huge bonus (attempting to start up a business in photography).
It's between these two lenses here:
smc PENTAX D FA MACRO 100mm F2.8 WR
smc PENTAX DA Star 16-50mm F2.8 ED AL (IF) SDM
Currently I have a K-3 and the 18-135 WR and the DA 50mm 1.8. Both lenses are doing very basic jobs right now. I would very much like weather resistance in my lenses for the hobby side of photography.
Thanks everyone.
03-26-2014, 02:10 PM - 1 Like   #2
These are VERY different lenses. IF you want/need macro, go for the 100mm - macro is not something your current lenses are providing. The D FA 100mm also works as, albeit a little long, portrait lens. The DA* 16-50mm will be a little sharper than your 18-135mm (in my experience) and will obviously be a little wider, but if you are really into landscape maybe a 12-24 would be a better supplement to your current lenses. I liked the DA* 16-50mm, but it is not a MUST HAVE lens IMO, and your 18-135mm already provides basic WR capability.
03-26-2014, 02:13 PM   #3
narual's Avatar
Are you only looking at the 16-50 as a wide angle lens? If that's the case, go with the 100mm macro, since the 16-50 isn't that much wider than the 18-135. If you want a wonderful wide angle lens, the 15mm limited is that (no weather resistance though). And I think the lens roadmap has a new wide angle zoom slated for this year that would presumably be weather resistant.
If you're looking for an upgrade in image quality and a little extra width, the 16-50 will certainly provide that over the 18-135.
I've only used the 16-50 when I said "I should really take this thing out of the bag and use it." It's never been my lens of choice. I use my 28-75 for indoor events and my 50-135 for most other things (and my 15mm ltd of course for wide angle… I rarely even use my 10-20mm anymore despite the much wider FOV)
03-26-2014, 02:20 PM   #4
QuoteOriginally posted by FlyingOrcas Quote
By which you mean? Are you saying that you're not happy with the IQ?
The 18-135 will serve you ok in the short term for portraits and enable you to decide what focal length you would actually prefer for this work. Certainly the 16-50 is better than the 18-135 for IQ, but given what you want - lenses for landscapes and portraits - is neither fish nor fowl.
You might also want to use the 18-135 for landscapes, taking a series of shots and stitching them together.
03-26-2014, 02:26 PM   #5
cali92rs's Avatar
That 100mm Macro is good for both macros (obviously) and portraits
03-26-2014, 06:03 PM   #6
Kozlok's Avatar
IMO, the 18-135 takes fine photos. If there is a sharpness issue with it, try calibrating focus. It's your most likely problem.
As far as which lens...none of what you chose. The 18-135 is more than adequate with decent light, like outside, where you are also most likely to need the WR, so you have those things covered. Your 50 is a decent low light and portrait lens. For the same $1000 you were going to spend, get a used DA15 and a Sigma 70mm macro. You'll have the macro you want, and the wide angle you want.
03-26-2014, 06:12 PM   #7
peterjcb's Avatar
the 100mm F2.8 Macro is a wonderful lens....go for it!
03-28-2014, 02:01 PM   #8
Buceemie's Avatar
Great advice from Hendrickdk.
I think every photographer needs a serious wide angle lens, they're so much fun to use and produce stunningly dramatic images. The Sigma 10-20 mm zoom is also fantastic. Not weather sealed but the kit zooms are perfectly adequate for nasty weather, and sigma's build quality is excellent.
By contrast I rarely use my macro lenses. They're fun and useful when needed, I just don't find closeups that exciting, and I don't have the time to set up elaborate macro shoots.
I'd get a good wide angle lens (15mm or wider) first. Eventually you'll have both
03-28-2014, 02:18 PM   #9
p38arover's Avatar
I just bought a 10-20 and am using it a lot.
I bought a 100mm macro a couple of years ago and haven't used it since the initial playing after purchase.
da, f2.8, k-mount, k3, lens, lenses, macro, pentax, pentax lens, photography, portraits, slr lens, smc, wr
Wide angle lens Sigma or Pentax J.R.Tec Pentax K-30 & K-50 12 03-03-2014 09:49 AM
Suggestion for a wide angle prime (FA or M) yusuf Pentax SLR Lens Discussion 3 08-18-2013 09:45 PM
Megakit (wide angle, macro, and telephoto kit) albanna47 Pentax K-01 6 03-27-2013 11:52 AM
0.5x wide angel attachment? or C-mount wide angle? MegaPower Pentax Q 55 01-23-2013 09:33 AM
All times are GMT -7. The time now is 12:19 PM. | See also: NikonForums.com, part of our network of photo forums!
