Originally posted by Susinok I am pleased with the K-20D, now that I have lenses that do the camera body justice. I tend to underexpose a bit anyway to bring out the color in my flowers and landscapes. I was wondering about the HD designation on the 15mm lens, since I know the 20D does not do anything HD just yet.
HD is just a technical term they use for the lens coating. It's HD instead of SMC because they tweaked the coating on the glass. The K20D just records the images that the glass sends through, so it will take full advantage of that HD (limited only by the sensor's characteristics, as I said before).
Quote: But in short, you all have convinced me, it's the lens. Though I'm still wishing for my K-3 now, I'll not be in a huge hurry about it. That 15mm lens may come first.
Make sure you look at a lot of DA 15 and DA 21 pictures (and maybe DA 12-24 as well) to make sure that you get the one that is more compatible with
your needs. While the DA 15 is a great lens, I for one am not a great fan of the ultra-wide look. I think as an effect it's great, but I don't want an ultra-wide as my main landscape lens. The whole "make the pebble in the front look huge and the mountain in the back look tiny" effect is cool, but I don't want most of my pictures to look like that.
For me I think the 21 would work great. I've actually got my sights on the 16-45 - like the 12-24 it's a great zoom for landscapes. Probably not quite as good as the limiteds, but for my limited budget I'm sure it will work great. DA 21 is my other option right now, as they are not that expensive on the used market.
Quote: Maybe it's time to put my unused pottery equipment up on Craig's List. That would let me afford both. Hmm..
Now you know the meaning of LBA
I've done the same thing with my music equipment. I still have some music equipment saved for the time when I will upgrade to a newer body...
By the way - another thing that we haven't really talked about much yet, is Post Processing (PP).
Learning that will also determine how good your pictures will turn out to be. Even a K-3 won't give you pictures that are as good SOOC (straight out of camera) as pictures edited by someone with good PP skills from a K20D or even a K10D.
Shoot RAW and learn to PP, should be your next assignment after you are happy with your basic lens setup
