03-30-2014, 10:27 PM - 1 Like   #1
Stacking HD-DA 1.4x Rear Converter AW
I just wanted to report I have tried stacking the new converter. The main reason is I was a bit disappointed there was no 2.0 launched. That would have been the ideal combination for my 200, 300 and 60-250. So when they finally arrived 1.5 weeks ago, I bought two :-)
One of course works great, but how does two actually work.
First some technical limitations. The camera does not recognise there are stacked converters, so inly multiplies the focal length ones.... That is a pity as it will give the wrong information to SR. I have no idea if this is a bug, or if it is a technical limitation with the way Pentax lenses communicate.
I did expect AF not to work on my DA300 or at least to be very poor, and I was right. I managed to get the focus to lock, but it took a lot of time and could not always be trusted. IF you manage to get the focus right, the combintation actually delivers decent quality.
Attaching a photo, ISO 1600, no tripod at full and 100% crop. One without noce reduction and one with (and a bit more sharpening).
PENTAX K-3  Photo
PENTAX K-3  Photo
PENTAX K-3  Photo
03-31-2014, 12:52 AM   #2
leungclj's Avatar
thanks for the info!
my x1.4 just arrived in the mail, I have always wondered what stacking the two would be like.
04-06-2014, 01:02 AM   #3
I am definitely going to use stacking more...but preferrable on a tripod, and with enough time to focus... It is definietly not for sport (on the 300 or 60-250).
04-06-2014, 02:53 PM   #4
Do you have any f2.8 lens (not important what focal length) to test autofocus on one of those?
04-06-2014, 03:12 PM   #5
jpzk's Avatar
QuoteOriginally posted by quarc Quote
So, you now have a 2.8X TC after stacking ? Am I interpreting this right?
That must be one heck of a PITA to try to AF this combo ... on any lens.
Just for info, have you tried the stacked TC's on the DA*300/4 with manual focusing ?
JP
04-07-2014, 10:41 AM   #6
QuoteOriginally posted by jpzk Quote
JP
I have, as long as I put my reading glasses so I can see clearly it works well
Woodpecker at feeder with stacked DA 1.4x tc's. Only cropping was to move the left side of frame in using LR. DA*300 f/4 x2 DA 1.4x tc (588mm)
Same woodpecker and feeder cropped about 50% using DA*300 f/4. Rainy dark weather not the best shots today
AF hunts and sometimes even gets lucky but for the most part not so much, have to switch to manual focus for a decent shot. Surprisingly the 60-250 does well in the little bit of testing I have done with it in AF and LV. Later I will test it some more.
All of my lenses need +3 fine focus adjustment. With 1 tc they take +7. Stacked +9. I need to send the K-3 in for focus adjustment but will have to wait a few months with the birds returning here don't want to be without a camera. Stacked the tc's will not work for BIF but I am stuck with the second tc due to the store return policy that I purchased it from using Amazon. Not sure what I am going to end up doing with it. For manual focus shots on wildlife looks like it will work satisfactory, but still not a Sigma 500 f/4.5 or 560mm when all is said and done.
Last edited by Cold Iron; 04-07-2014 at 12:45 PM. Reason: Edit 540mm to read 588mm
04-07-2014, 11:20 AM   #7
No, it should be 1.4x1.4=1.96x, so about 2x TC.
The result looks very good!
04-07-2014, 12:00 PM   #8
QuoteOriginally posted by grahame Quote
Not exactly.
1.414113562373095 x 1.414113562373095 = 2.000000000000000
Because 1.4 is short from √2
04-07-2014, 12:06 PM   #9
QuoteOriginally posted by romeck Quote
You are right. :-)
04-09-2014, 07:21 AM   #10
Hi. I'm not sure if someone noticed my note before, so I ask again if it's possible to make a test with any f2.8 lens to check if these new Pentax TC's focus reliably when stacked?
I have now only a Kenko 1.5TC and it is a nightmere even on f2.8 lens when it comes to auto focus and I was hoping I could have two of the Pentax TC's to covert a AF 300mm f2.8 into a AF 600mm f5,6
04-09-2014, 09:10 AM   #11
I tried stacking both tc's with the DA*16-50 f/2.8 and also the DA*55 f/1.4. It required manual focusing for both lenses to focus reliably all of the time. They hunt for focus with the tc's stacked on my K-3, sometimes they hit focus but most of the time they don't. At least in my testing.
04-09-2014, 11:40 AM   #12
audiobomber's Avatar
I stacked an HD 1.4x and Kenko 1.5x on a DA*300. AF was as bad as the Kenko alone. IQ was not up to standard (not pixel sharp). I will use the lens and HD TC from now on, and crop.
04-09-2014, 02:52 PM   #13
Thanks for the news. So I will save $600 as I will buy only one TC ...
04-09-2014, 03:25 PM   #14
Tried a stack of a HD 1.4 and AFA 1.7x. No extra detail revealed, and AF / aperture limitations were frustrating. So just using the HD going forward, it seems to me to be a fine investment so far.
05-01-2014, 03:45 AM   #15
I will try stacking on my DA200/2.8. I have not seen any reason to do it as it makes more sense (for me) to put a signle TC on the 300. But for those with only a 200 it of course makes sense, so will try. As I managed to get AF to lock even on the 300/4, I would guess it to work better on the 200/2.8, but will let you know when I have tried it.
1.4x rear converter, bit, converter, focus, hd-da 1.4x, k-mount, pentax lens, slr lens
HD Pentax-DA 1.4x AW AF Rear Converter v.s Kenko Pz-AF 1.5X Teleplus SHQ Unregistered User Pentax SLR Lens Discussion 19 04-03-2014 02:52 AM
Wanted - Acquired: Rear Converter-A 1.4x-L RockvilleBob Sold Items 2 04-08-2013 07:21 AM
smc PENTAX-DA 1.4X REAR CONVERTER SDM koper Pentax SLR Lens Discussion 12 08-17-2011 07:33 AM
Rear Converter-A 1.4x-L and DA* 300mm Tom S. Pentax SLR Lens Discussion 3 02-02-2009 06:45 AM
All times are GMT -7. The time now is 11:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
