04-02-2014, 04:58 AM   #1
pentaxpete's Avatar
Free SMC PENTAX-F 100-300mm 4.5-5.6 struggles !
I have a 100-300mm f4.5-5.6 SMC Pentax-F series given to me with a 1996 Pentax MZ-5 and it does not 'auto-focus' so I use it on 'manual' focus but the other trouble is that sometimes it 'zooms' OK and then suddenly stops at 300mm -- then if I turn zoom ring back and forth a few times something will 'click' and it zooms again !! Is it worth sending off -- my wife doesn't want me to spend any more money on 'Old gear' !! Or can I take it apart myself
04-02-2014, 05:28 AM   #2
TER-OR's Avatar
My 55-300 did something similar, after it was damaged. I sent it to CRIS for service, which was about half the cost of a replacement used one. They returned it better than ever, they calibrated the autofocus so now it's really good.
Right now you have a worthless lens. Repair it and you can use or sell it.
Being an old lens, though, the parts may not be as readily available. Do you have a repair service you can ask - and will they provide an estimate if you send it?
04-02-2014, 05:53 AM   #3
if you turn the focus ring, does the little screw drive coupler turn in the mount? it'll look like a little flathead screw recessed a bit into the mount.
also, make sure all the contacts are clean, a q-tip and rubbing alcohol works wonders (moist, not dripping wet)
100-300mm, k-mount, pentax lens, pentax-f, slr lens, smc, smc pentax-f 100-300mm
For Sale - Sold: SMC PENTAX-F 1:4.5-5.6 100-300mm walay Sold Items 9 07-29-2009 11:57 AM
SMC PENTAX-F 1:4.5-5.6 100-300mm Aanund Pentax SLR Lens Discussion 14 07-01-2007 09:27 PM
All times are GMT -7. The time now is 06:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
