04-04-2014, 01:52 PM   #1
problem with SMC M 50mm 1.4
Hello all,
I've just bought an used Pentax SMC M 50mm 1.4 lens which is in a pretty good status.
However, trying to use it with my K10D camera I've encountered these problems: when I mount the lens on the camera, the apperture is opening completely, and rotating the aperture ring is useless.
But what is extremely concerning is that the camera is not shooting in any mode. I usually shot in M mode, but with this lens on, the time is not shown anymore on the display (actually in any mode on the display is just this: "F- -" (blinking).
Please provide some advice on these issues, thanks!
04-04-2014, 02:04 PM   #2
QuoteOriginally posted by sorins Quote
This is normal. The lens won't stop down until you go to take the shot. Also, no aperture information is transmitted to the camera, so the camera never knows what the F stop is. You have to 'stop-down' meter to get the correct shutter speed.
Follow these instructions to use the lens:
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
04-04-2014, 02:06 PM   #3
sundr's Avatar
Don't worry. That is how it works. The aperture closes down when the shutter is pressed. And ther are no contacts on the lens to communicate with the camera so aperture does not read on the screen. Use manual mode and use the green button to meter the shot. I'm sure other replies can give you more references. Cheers:-)
04-04-2014, 02:30 PM   #4
Thank you Adam & Sundr, it works now! You're right, I remembered this function only when you mentioned it! As I've heard it is a great lens, I can't wait to check this. Have a great day, you made mine great!
04-04-2014, 03:33 PM   #5
One more thing before you go out and play. The stop-down metering on your camera is not particularly reliable. The raw meter output with non-A contact lenses is not linear. The behavior varies between lenses, but you can probably expect 1-2 stops underexposure at apertures wider than about f/4.
There is an additional caution for low light and narrower apertures. The meter on your camera has a lower sensitivity limit of 0 EV(100). That corresponds to 1 second at f/1.0 at ISO 100 at the meter sensor. Normally that is not much of a problem as long as you are metering with the lens wide open. Stopped down is another situation entirely. In dim light and narrow apertures, the light to the meter may fall below that 0 EV(100). The result is an unreasonably high shutter speed. This is the case regardless of how high you set the ISO.
04-05-2014, 10:26 PM   #6
Steve, you're right and I observed this already while start playing with this new toy. My plan is to upgrade to K3 which I believe solves most of these issues.
However, thanks for advice!
04-13-2014, 11:33 PM   #7
leungclj's Avatar
Hi Sorins,
I used to have the K10D with the M 50mm 1.4 too, for 8 years! That lense was on the camera for 90% of the time, its great! I recently upgraded to the K3 and things are not so good...
Its not the camera's fault, well... it is actually... Because the K3 is soooo much better than the K10D, I have noticed that lense its not perfect, it is not a very sharp lense. I still love my 50mm 1.4, I love big eyes. But I also purchased the 50-135, the sharpness on that is incredible. Of course, those are 2 different lenses, but if you start shooting with such high pixel camera, the flaws of the M 50mm 1.4 starts showing, the only way its to step down 1 stop. I am considering to upgrade to the DA* 55m f1.4
04-14-2014, 12:49 AM   #8
Thanks leungclj, it's good to know this. I'd also like to have the DA* 50/1.4, but there are already too much money to be spent (it's not just the K3 I want to buy, but also the Sigma 10-20/3.5 and the Tamron 70-200/2.8, all of these will take almost $3000 from my pocket). I have also a Sigma 28-70/3.5-4.5 and the Tamron 90/2.8 (which is great for portraits on my K10d), so I will cover pretty much all situations.
50mm, camera, display, k-mount, lens, mode, pentax lens, slr lens, smc, smc m 50mm
Focusing Problem With my Pentax-M 50mm 1.4f tezomoy Troubleshooting and Beginner Help 14 02-20-2014 04:49 PM
For Sale - Sold: Pentax SMC A 50mm f 1.4 and SMC M 50mm 1.4 davidgreen3003 Sold Items 5 09-17-2013 09:11 AM
For Sale - Sold: Pentax KM with Pentax SMC M 50mm 1.4 wmf2012 Sold Items 2 09-01-2013 05:49 AM
SMC Pentax-M 50mm 1.4 VS SMC Takumar 50mm 1.4 iNicole Pentax SLR Lens Discussion 16 08-23-2012 07:50 AM
portraits with SMC M 50mm 1.4 slip Post Your Photos! 17 03-29-2007 05:13 AM
All times are GMT -7. The time now is 06:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
