04-04-2014, 05:09 PM   #1
jatrax's Avatar
Question on the Pentax-F AFA 1.7x
Last fall I used the AFA 1.7x and my Pentax-A 400mm f/5.6 at Yellowstone. I really was not happy with the results and at the time put it down to my inexperience with 500mm lenses.
However, I've been testing the combo again and also with my A 200mm f/4 and discovered that the auto focus is severely front focused on my k-3. I thought I would just dial in a little AF fine tuning and all would be good, but it appears that AF Fine Tuning does not work with the AFA adapter. In fact the lens is always reported as "A series lens" in Lightroom even if a modern FA or DA lens is attached.
So a couple of questions:
1) Has anyone tried AF fine tuning with the AFA adapter and made it work?
2) Has anyone else discovered problems with AF accuracy with the AFA 1.7x?
3) Has anyone sent it in to Pentax for calibration and if so what were the results?
04-04-2014, 05:13 PM   #2
Have you tried adjusting the focus on your 200mm lens using the focusing ring? If you just set the lens to infinity, for instance, that would limit the AF adapter's AF range.
04-04-2014, 05:19 PM   #3
jatrax's Avatar
Sure, you have to manually focus close enough to be within the range of the AFA. I do get a focus confirmation beep and 'green hex' but when I examine the image it is front focused. Using a Spyder Lenscal for testing at about 25 feet distance. I could understand if the AFA would not lock focus, but I do get a focus confirmation.
04-04-2014, 06:54 PM   #4
carrrlangas's Avatar
Does the A400/5.6 front focuses if used without the AFA adapter? Use the general fine tune adjustment..
04-04-2014, 07:18 PM   #5
I was trying to see if I had any pictures with the k3 and 1.7 and cant seem to find any...I know I have some...will try to take some shots this weekend with it to see if I have the issue...I don't have any "a" lens to use it with so will be the da 300..is that ok...carrianges the a lens is manual focus unless you use it with the 1.7 adapter and then it becomes autofocus
04-04-2014, 08:14 PM   #6
QuoteOriginally posted by carrrlangas Quote
On the K-5 in AF Fine Adjustment use the 'apply all,' which is what I believe carrrlangas was saying. I had to set mine all the way to 10 (I forget whether + or -) and it was almost enough.
Also make sure you manually input the focal length to 1.7 times the FL of the lens alone (i.e. 650 or 700mm when used with the A400) or the SR will blur your image.
In addition, you should normally be using a minimum distance of 57 feet when doing the AF adjustment on a 700mm lens. See the Distance Tool here: http://michaeltapesdesign.com/lensalign.html
04-04-2014, 08:17 PM   #7
jatrax's Avatar
QuoteOriginally posted by pearsaab Quote
Sure, thanks for checking. I just assumed that I could use AF fine tuning, now I'm considering sending it in to CRIS, but I don't know if that will help or if it is even possible to adjust the AFA 1.7x
---------- Post added 04-04-14 at 08:19 PM ----------
QuoteOriginally posted by DSims Quote
Hmm Ok, I'll try that tomorrow, too dark now. But if I understand that right I would then need to turn it back off when using any other lens?
04-04-2014, 08:27 PM   #8
Yes, the problem is you'll have to remember to re-set it for any other unrecognized lens.
Also note my added comment above about the focusing adjustment test distance.
04-04-2014, 08:44 PM   #9
jatrax's Avatar
In addition, you should normally be using a minimum distance of 57 feet when doing the AF adjustment on a 700mm lens. See the Distance Tool here: LensAlign
Good info, thanks. I know something is not right because I've lots of shots from Yellowstone that are not right. I initially just thought it was my technique but now I think it was the AFA. Shots from the 400 alone are nice and crisp.
04-04-2014, 08:50 PM   #10
Sounds like a good lens for a reasonable size, FL, IQ, and price.
04-04-2014, 09:06 PM   #11
jatrax's Avatar
Yep, love the 400mm f/5.6. Wish it was f/4 but then it would weigh a ton. As is you can pack it along without too much trouble. I used it and the DA*60-250 mostly @ Yellowstone. Now if I could get it to work reliably with the AFA I would be a happy camper. Not going to be too useful in low light but in decent conditions it should work.
04-04-2014, 09:24 PM   #12
OJGoreng's Avatar
I had consistent severe FF using it with my K f/4 300mm on both the K-5 and the K-3. With my DA* f/4 300mm, it's perfect, though.
04-04-2014, 09:28 PM   #13
Good to hear. I'll consider it if I ever want to go beyond my F*300 (but I might consider the HD 1.4x TC first for ~420/6.3 - although I still won't be able to get beyond ~510/8 using that lens and the 1.7x AFA).
04-06-2014, 03:43 PM   #14
here are a few with the k3 afa1.7 and da300...I think anything that was moving was solid...BIF are not quite so simple but I think it told me the adapter was doing ok
1.7x, adapter, af, afa, k-mount, lens, pentax lens, results, slr lens
For Sale - Sold: Pentax AFA 1.7x Teleconverter GaryH Sold Items 2 10-02-2013 03:56 PM
For Sale - Sold: Pentax AFA 1.7x teleconverter GaryH Sold Items 5 05-03-2012 09:59 AM
1.7x AFA and min aperture question rfortson Pentax SLR Lens Discussion 2 10-12-2008 03:54 AM
All times are GMT -7. The time now is 11:12 AM. | See also: NikonForums.com, part of our network of photo forums!
