I've been shooting the K-3 with DA*300 using the 1.4 HD TC. It is sharp, focuses well, but seems to amplify mirror slap. I shoot on a monopod with a gimbal, the Jobu-Design combination. It has been very hard to get a sharp shot, and today with some light being able to shoot at 1/1600 it was slightly better, but far too many soft shots. I have one hand on the body, focusing and shutter, the other firmly holding the lens past the focus ring, and I can feel the vibration transfer down the lens.
I set the body and lens on a tripod to set up the focus adjustments. The lens only was fine with standard shutter release, but the lens plus TC was very soft with motion blur unless I shot mirror up. Not a little bit worse, but sharp to can't read the numbers soft.
Has anyone else experienced this? Do I have some malfunction or looseness in the lens or TC that is causing this?
This is far worse than any other long lens that I have shot.
Edit:
It could be the lens. If you hold your DA*300 and shake it, do you hear movement inside?
