04-22-2008, 07:20 AM   #1
Buddha Jones's Avatar
I hate math, so help me....
How many extension tubes do I have to add to the DA*200mm to get it to 1:1?
Or should I just not even ask?
04-22-2008, 07:31 AM   #2
jshurak's Avatar
get a reverse ring!!
04-22-2008, 07:39 AM   #3
QuoteOriginally posted by jshurak Quote
Does that work without an aperture control? I'm actually just curious as I don't have a DA here to see what it does when its off anymore. I thought they closed down.
04-22-2008, 07:45 AM   #4
aegisphan's Avatar
200mm extension tube
04-22-2008, 07:55 AM   #5
Lowell Goudge's Avatar
Just to make the answer better understood.
Any lens produces 1:1 magnification when the distance from the front element, to the subject is exactly 2 times the focal length. This requires an extension tube equal to the focal length of the lens to allow an in focus image.
04-22-2008, 07:58 AM   #6
Ed in GA
Guest
Thanks,
That is good information to know.
But, this begs another question from me.
If I add a 70mm extension tube to a 70mm lens, do I now have the equivalent of a 140mm lens?
Ed
04-22-2008, 08:06 AM   #7
aegisphan's Avatar
Exactly what Lowell said. Personally, I think you should try the extension tube on the 105 macro instead. On a macro lens, things get more complicated. There is a formula floating around:
(Lens FL + length of the extension)/Lens FL.
However, in reality, the magnification is higher than this formula. It's probably due to the real focal length of the lens when it's at 1:1.
04-22-2008, 08:07 AM   #8
aegisphan's Avatar
QuoteOriginally posted by Ed in GA Quote
Thanks,
Ed
Without the corrected glass element, you can't focus to infinity. So your setup is not exactly equivalent to a 140mm lens.
04-22-2008, 08:11 AM   #9
Thanks,
Ed
Ed
No what you have is a 70mm lens that can focus from a range of about 125-140 mm depending upon the close focus of the lens without extension tubes.
k-mount, pentax lens, slr lens
Camera and Lens Math - EASY! Venturi Photographic Technique 30 05-15-2011 04:55 PM
Question Feedback Math geauxpez Site Suggestions and Help 3 06-11-2010 07:04 AM
Any Math people? Fl_Gulfer General Talk 3 11-11-2009 12:08 PM
math rationalization for LBA nostatic Pentax SLR Lens Discussion 13 01-06-2009 12:55 PM
How to do the math for a closeup lens? raider Pentax SLR Lens Discussion 6 03-11-2008 05:57 AM
All times are GMT -7. The time now is 12:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
