Originally posted by Sigmund I wonder if old hands can advise on this. The lens just arrived and I'm not sure the manual focus is what it should be regarding feel. Rotating it to infinity there are about eight points at which the ring feels rough and there's slightly increased resistance - almost as if there was a poor indent machining job. There's nothing but smoothness focussing down.
I noticed that my DFA 100 mm macro makes a slight noise when manually focusing. It is like it is turning a gear mechanism inside the lens, not any kind of binding or stiffness at all. The manual focus is smooth and well damped end to end. I never saw this as a problem. Now I also have DA 35 mm Macro limited and it also makes the same slight gear noise. Hopefully this is all you are observing. Both lenses work perfectly on the camera, autofocus or manual focus and I rate both or them as a 10. If you have unevenness in the feel of the focus ring, you may have a defective lens and should return it. Good Luck.
