04-18-2014, 03:26 PM   #1
Which lenses work well with macro tubes?
Hi,
I am reading "Cambridge in Color" article on macro tubes, and they mention that many non-macro lenses have poor quality when used with tubes - they are simply not designed to focus this close.
What is your experience with that? I would mount a 25mm tube on DA40mm limited, or on a smc takumar 55mm F1.8.
04-18-2014, 03:41 PM   #2
QuoteOriginally posted by rrstuff Quote
Hi,
Normally the point of tubes is to go beyond 1:1 magnification, so if the lens you're using doesn't offer that to begin with, you may as well just use a dedicated macro lens.
If you don't have a macro lens, then you will at least need a lens with an aperture ring and good manual focusing- so the 55mm fits the bill.
04-18-2014, 04:02 PM   #3
Vitor's Avatar
In order to use this old set I need two differente adapters (male and female). Is there any set available?
Best regards, Vitor
04-22-2014, 12:56 AM   #4
Digitalis's Avatar
The Takumar 55mm f/1.8 would be your best bet - it is always best to use a fast lens when using extension tubes as the viewfinder become dimmer as the lens is physically further away from the focal plane. The speed of the takumar 55mm f/1.8 will help with focusing, and the lens is optically superb at any focus distance.
k-mount, lenses, macro, pentax lens, slr lens, tubes
Macro extension tubes with the Q MarinatedHerring Pentax Q 5 12-18-2013 10:11 PM
which of my lens is best for macro work? WA-surfer Pentax SLR Lens Discussion 10 04-25-2013 09:06 PM
How well do M42 lenses work on K mount pentax cameras? geekette Pentax SLR Lens Discussion 6 04-13-2011 03:20 AM
Which prime lenses would work well? Vantage-Point Photographic Technique 9 11-08-2010 12:38 PM
For Sale - Sold: Everything Macro: Bellows, Ext. Tubes, Macro Lenses MikeDubU Sold Items 12 03-14-2009 07:10 PM
All times are GMT -7. The time now is 04:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
