Originally posted by jatrax I never use anything except spot focus which might explain why I never saw any issues.
I actually saw quite a few 3rd party lenses had AF accuracy issue on K-01, and I also saw quite a lot threads post here complaining AF issue on K-01. Tamron 28-75 is one of them gets a lot complain.
I have tested many time, and have excluded the possibilities of AF point selection and SR related problems. And usually more obvious when the lens is stop down than wide open, unless the DOV is wide enough to cover the problem.
And it is not 3rd party lenses only. My DA55/1.4 has similar but much minor BF on K-01. The lens is very very sharp even wide open, but I was surprised to see less so at F 1.8 and 2 on K-01.
interestingly, live view (contrast detection) AF on K5II is just fine. I noticed this problem on K-01 only. I even returned a K-01 for that reason but the 2nd came with same problem. I use small primes on K-01 only so not an issue for me. Apparently, the AF chip on the camera could make mistake, even using live view.
