Originally posted by TzalamChadash the second need is the extra reach - basically for going out on hikes, animals father away, etc. when I know I will want extra reach. Here I can see the advantage to the Pentax with faster AF and WR over the Tamron which offers a bit wider angle on the short end - price is close together on these two and will probably stay with Pentax on this choice
I'm not rushing on this decision so if theer are any Pentax, Sigma, Tamron, (Samyang?) or others with stuff on the lens roadmap would be happy to hear about what's in the pipeline as well.
The DA55-300 is good, but I sold mine because the IQ over 135mm wasn't as good as I wanted. I admit I'm particular about IQ, so you might be happy with it, as I was for a while until I realized none of my longer shots with it were very exciting (the opposite is true with my F*300, so it was the lens - not the shooter - in this case!). Therefore I now shoot only primes over 135mm (which is only 2 lenses - K200/2.5, and the F*300/4.5). Most of the time I have just 135mm (either the FA135/2.8 or DA*50-135/2.8) and 300mm with me - I don't need anything in between. The IQ from the F*300 is so good that it makes up for any lack of zoom. Plus, it's lightweight for such a quality lens.
I'd suggest you consider the DA*200 (or FA*), DA*300 (or F* or FA*), and Tamron 70-200/2.8 here. If you want a zoom the Tamron is a really good value. And the *200 and *300 lenses are even a little better, IMO (but you normally wouldn't need both).
From your other comments it sounds like your budget is just flexible enough that you could fit one of these in.
I'd suggest either a *300 or the Tamron 70-200/2.8 be added to your DA18-135 for now. Then use your DA50/1.8 indoors a little more, and determine whether you mostly need a longer lens, a shorter lens, or both equally. This will help you determine your final step.
The Tamron 28-75/2.8 has proven to be a good solution for other Pentaxians indoors (I know crewl1 likes it on his K-3, for example) so I'd be hesitant to spend more without a good reason. I would think the DA50/1.8 would already suffice in
some of those situations, but if you find you need
longer most of the time consider an (unfortunately more expensive) FA77/1.8 or maybe DA70/2.4 rather than a 28-75 which you're going to keep zoomed out most of the time. Both of those primes are excellent wide open, while the Tamron should be probably be stopped down a little for better performance (to f/3.2 or f/3.5). So while on paper the Tamron looks nearly as good - with the benefit of zoom - in practice you're comparing f/3.5 with f/2.4 with f/1.8 - hence the correspondingly rising prices!
OTOH, a Tamron 28-75/2.8 plus a 70-200/2.8 would make a nice combo!
