Originally posted by Newtophotos I read somewhere that the f value (effective value?) of a lens drops as the sensor size decreases. Is this true? Will a FA 31 f1.8 have an even lower f value on a APS-C sensor camera?
Different people use this f-value for different things.
1)
Correct Definition, but not particularly useful: The f/number is the focal length of the lens divided by the aperture diameter.
This number is solely a property of the lens.
2)
User ramification A: The user-selected aperture (f/number), along with the shutter speed and sensor/film sensitivity, determines the exposure of the image to available light.
This uses the f/number number as solely a property of the lens, i.e., the same number as the one given in 1).
3)
User ramification B: The user selected aperture (f/number), determines the depth of field of the image.
This number is a property of both the lens and the sensor size.
To alleviate the sensor-size dependency, people use 'equivalent' F-stops.
So, as used right now, ramification A and B aren't separated, and some people use 'actual' F-stops and 'equivalent' F-stops.
Confusing enough? There's an easier method, but it involves equivalent F/stop and equivalent sensitivity, but no one actually uses this system, so if you're just starting it's better not to learn it.
