05-15-2014, 04:30 PM   #1
Vivitar P/K-A lens doesn't mount on K-30
Hi there,
I bought a vintage 80-200mm Vivitar zoom lens and I expected it mounts on my K-30 with no issue, but it doesn't!
After a bit of inspection I realized that Vivitar lens has a longer metal tip (i have no idea what it is called) compared to my vintage Pentax lenses.
See the attached photo. The left one is the Vivitar lens and the right one is an SMC Pentax 135mm lens.
How can I fix the issue? If I cut the tip does it solve the problem?
PENTAX K-30  Photo
05-15-2014, 04:58 PM   #2
Got it in one.
05-15-2014, 04:59 PM   #3
Yes, some old Vivs have that. Some people Dremel off the extra, but you can probably just remove the entire ring by removing the correct screws...
05-15-2014, 07:05 PM   #4
dms
Generally held on by 3 screws, remove them and then the shield and you should be fine. You can also at that point grind it down following one of your other lenses as a guide.
05-15-2014, 07:51 PM   #5
So, if I can remove it and it's fine, what is the functionality of the part at all?
05-15-2014, 08:33 PM   #6
dms
I believe it is there to protect the aperture actuation lever from being bent--which can happen relatively easily--in which case the lens may not stop down to set aperture. It may also afford some additional protection from internal reflections (lens flare).
05-15-2014, 09:10 PM   #7
Just two screws. Unscrewed and it's working perfectly now. Thank you all for your help.
issue, k-30, k-mount, lens, pentax, pentax lens, slr lens, tip, vivitar, vivitar p/k-a lens
Using K Mount Manual Lens on K-30, K-50? Relativity Pentax K-30 & K-50 11 07-08-2014 04:05 PM
Sears 80-200mm PK-mount lens doesn't mount on K1000 kylemsguy Pentax SLR Lens Discussion 8 09-19-2013 11:44 AM
Vivitar p/k lens not mounting on K-5 weave2d2 Pentax SLR Lens Discussion 17 06-14-2013 07:55 AM
Lens doesn't mount on K-01 geirix Troubleshooting and Beginner Help 28 03-20-2013 05:53 PM
K Mount lens on K-30 TropicalMonkey Pentax K-30 & K-50 5 11-20-2012 07:30 AM
All times are GMT -7. The time now is 06:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
