05-19-2014, 05:42 PM   #1
Trudger1272's Avatar
How to see if a lens is damaged...?
If you received a lens that appears to be scratched or maybe have something in it, what would be the proper way to test the images to see if they are affected?
When I look at the 31mm I just got on the surface it's fine, looking through it front to back wide open is cool.
But looking back to front it appears to either be scratched or have something in it. Whatever it is I know it must be very small.
Thanks!
05-19-2014, 05:49 PM - 1 Like   #2
Na Horuk's Avatar
One thing you could do is shine a flashlight into the (dismounted) lens to see if anything shows up.
A test you could try is setting the lens to minimum focus (all the way away from infinity) and aperture to f16 or even f22. Then take a bright photo (white wall, sky) to see if any spots or something shows up.
05-19-2014, 05:52 PM - 1 Like   #3
tromboads's Avatar
Dirty lens article
Did you pay a fortune for it?
Don't worry about it! take pictures darn it!
05-19-2014, 05:57 PM   #4
QuoteOriginally posted by tromboads Quote
$839
One thing you could do is shine a flashlight into the (dismounted) lens to see if anything shows up. A test you could try is setting the lens to minimum focus (all the way away from infinity) and aperture to f16 or even f22. Then take a bright photo to see if any spots or something shows up.
Thanks, I'll give these a try.
05-19-2014, 06:20 PM   #5
Here is an article from RioRico who was a very frequent poster / member here (and one of the most knowledgeable folks around on lenses), on buying and checking out used lenses.For the amount you paid, you should not be suspecting that it is either scratched or something rolling around loose inside.
05-19-2014, 07:04 PM   #6
Dirty lens article
QuoteOriginally posted by interested_observer Quote
PAWNSHOP LENSES (and other used lenses) - A Buyers' Guide
Thanks for the links!
---------- Post added 05-19-14 at 07:27 PM ----------
I've done this and can only see a little dust, but nothing in the area where it would be located.
front, k-mount, lenses, pentax lens, slr lens
Anyone else see this damaged lens up forsale? jaywes Pentax SLR Lens Discussion 8 11-01-2013 11:20 AM
31 f1.8 with damaged lens hood... how to repair? Teknuccio Pentax SLR Lens Discussion 9 02-02-2013 03:24 AM
Dropped my camera, damaged a lens - What did I do and how to fix? ChopperCharles Pentax SLR Lens Discussion 6 06-05-2012 06:47 AM
Is there a way to see if batteries in grip has run out separately? bkhl Pentax DSLR Discussion 2 05-09-2011 09:36 AM
How to know if a lens is made for Pentax??? gut1kor Pentax SLR Lens Discussion 8 07-20-2010 12:31 PM
All times are GMT -7. The time now is 10:17 PM. | See also: NikonForums.com, part of our network of photo forums!
