05-20-2014, 12:12 PM   #1
DA 16-45 uncorrectable back focus *only in middle range*
Hi all,
I've been doing some focus testing on suspicions that my 16-45 might need adjustment. I found that my previously selected fine adjustment of +5 was inadequate when shooting at 28mm.
I found that at BOTH 16mm AND 45mm, a correction of +7 or so is adequate. However, at 28mm even with a +10 correction I still get significant back focus.
I did my tests in moderate indoor fluorescent lighting, at a distance of about 10 feet.
Any suggestions?
(Lens was purchased used from KEH almost a year ago, return / warranty is not an option)
Thanks.
05-20-2014, 12:46 PM   #2
You don't mention which camera body you were using (and it is not in your member profile, either). And you also don't tell how you did focus. Was it manual focus, autofocus, or contrast autofocus (LiveView)?
If you were using a K-5 and autofocus without LiveView, the problem may be related to the inconsistent AF of this camera in fluorescent light (depends on frequency mix of the llight). There are multiple threads about this subject from the time short after the K-5 was introduced. This problem could only be fixed by hardware mods, not firmware. It was cured with the K-5 II and K-5 IIs.
In any case, you should try it again with natural light.
05-20-2014, 12:51 PM   #3
Oh, sorry. Camera body is a K-5. I don't have any other bodies to test with.
I did my testing from a tripod, using multiple methods:
Focusing using phase AF then switching to live view to check focus accuracy
Focusing in live view to actual optimal focus and then checking to see if phase AF would focus confirm
Focusing using phase AF and eyeballing focus
*only in middle, 28mm, adjustment, correction, da 16-45 uncorrectable, focus, focus *only, k-mount, pentax lens, slr lens, uncorrectable back focus
pentax da 16-45 vs 16-50 da* for K5? gf1 Pentax SLR Lens Discussion 18 11-16-2013 10:14 AM
Pentax DA 16-45 Focus issue and poor overall quality tigershoot Pentax SLR Lens Discussion 14 03-01-2010 10:18 AM
DA* 16-50 fringing, back focus help (pics?) DuckysDoll Pentax SLR Lens Discussion 2 03-08-2009 01:02 PM
DA* 16-50 vs DA 16-45 in IQ Ash Pentax SLR Lens Discussion 38 02-03-2009 12:59 PM
DA 16-45 focus lock problem barendvl Pentax SLR Lens Discussion 15 06-27-2007 07:11 AM
All times are GMT -7. The time now is 06:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
