Originally posted by condor27596 Lens can wiggle 5 mm but can't dislodge it. Wiggle means rotate.
---------- Post added 05-23-14 at 09:00 PM ----------
In addition to the memory issue my eyes are no good. I can't figure out where to dremnel or insert feeler gauge.
Ok if you can wiggle about 5mm then It it the clip that's holding the lens.
If you have the feeler gauge, from memory, I think the clip is at about the 10:00 position when facing the camera
Slide the feeler gauge between the lens and body at that position as suggested previously, with a little curl at the end that will hopefully catch the clip, then try to turn the lens off
