I'm back to update this situation. As was the case three years ago, I'm again about to leave on a trip, and after a couple of years of perfect behavior, my 17-50 AF has again gone out to lunch. Same intermittent AF/MF switching issue - it's like it loses contact.
Here's new info: this is an important trip, and I really like the Tamron, so I bought another one from KEH. 100% identical behavior. The lens will usually make one attempt to focus, and at the end of the run (when the focus gets close, at least), will drop the body back to MF mode. In live view I can just move the camera slightly and the body will keep toggling into and out of AF. But on my bodies, the 70-300 LD Di, 10-20mm Sigma, and a whole bunch of screw-drive (and non-screw-drive) Pentax AF lenses work perfectly.
Oh and the KEH copy: also exactly a -10 (or maybe -11 if it was there) on microfocus.
The odds of this happening with my two different K5 AF mechanisms (K5 and K5ii) AND two different copies of the lens are... wow. I don't know what to do. MF on this lens isn't horrible, but I'd really like AF.
Incidentally KEH was good about taking the lens back, no hassles. They were as mystified as I am.
---------- Post added 04-09-2016 at 08:26 AM ----------
Originally posted by niceshot Hi Tibbitts you don't say why they didn't resolve it. Was it something they could not fix
Sorry if I hadn't explained but Tamron returned the lens basically not identifying the problem, just saying they'd cleaned and adjusted it under warranty. I can't blame them, since for a couple of years now, I haven't experienced the problem either, and if it can't be reproduced, I can't expect them to fix it.
