Originally posted by theraven871 You make some very good points and have been able to articulate them well. I completely understand your philosophy here and it makes sense.
My vague comment of "not good enough" was based on a day of shooting indoors and outdoors with the lens.
It didn't provide consistent performance. It does have a "sweet spot" like other lenses do. But even in its sweet spot, it didn't provide consistent results.
Image quality was either incredibly sharp, or too soft. This occurred standing in the same position, using the same settings (I shoot full manual) and from the same composition.
Maybe I just got a bad lens??
That's been an observation of mine recently with all lenses. I'm not really clear on what's going on, but I'm not liking it. I suspect it's that I changed the AF settings to shutter release priority from focus priority to increase my frame rate in burst mode for my Hummingbirds. It means the the shutter goes whether the subject is in focus or not, and it definitely affects you keeper rate, in all lenses. I don't know if your issue was similar.
If you get one sharp image, you should be able to get 95% of them sharp.
Quote: But the difference with the DA*50-135 (and only the DA*50-135, I think) is that when looking at the images taken with it, it never even occurs to me to think "gee, if I'd only taken that photo with a prime it would've been even better!"
The only real comparison here we did was DA*60-250 against a Tamron 90, the images were very close to identical, but the Tamron had slightly better micorcontrast, so would I change lenses if we were in the 90mmm with the DA* ? Maybe if I had enough time, but probably not. I suspect your experience with the DA* 50-135. The DA* 16-150 however, from what I've seen, there are many better options at many different focal lengths.
But I'd certainly argue everyone should own either the DA* 50-135 or DA* 60-250, based on shooting style. Those two lenses are awesome.
Quote: As embarrassing as it is, I've never purchased anything in this range.
I'm debating if I want to try the 35mm F2.4 (Its SO cheap), but I'm wondering if I would be happier with the quality with a GOOD 17-50mm Lens.
I use my 21 ltd. way more than I use my 35...
My wife uses the Tamron 17-50 ƒ2.8. It's an awesome lens for not that much money.... there are times when her images so much outshine my 18-135 I feel like throwing it in the river. The 18-135 seems to be able to equal it from time to time, but when you nail one with the Tamron, you're not going to be able to match it with the 18-135, it's just too narrow a range for me most of the time.
For her shooting style, she uses the tamron 17-50 and Tamron 90 macro, where I would use the 18-135, and she gets excellent results with that combo.
By the way, your Sigma 70-300 if it's like mine is excellent from 60- to 150mm. After that it drops off considerably. In out tests at 90mm, it was just a tad behind the DA* 60-250 and Tamron 90 macro, to the point that I still find it some what disturbing how close it was. A lens that cheap has no right to be that good.
