After reading a few positive reviews on the Internet, i found a Vivitar 2x teleconverter, with electric contacts, and marked P/K-A R-P/K.
As the name suggests, it HAS the Ricoh pin (which is not a problem, as it won't get stuck on AF Pentax cameras), and SIX electric contacts.
Mine has the back flange (camera side) colored in black, so the black enamel should be scratched a little, just where the seventh electric contact of a modern Pentax camera comes in contact with the flange. Other way the diaphragm values can't be read in the viewfinder (or on the top LCD). The converter should work well without that small modification (and the EXIF should include diaphragm values), but IMHO it would be a pain where the sun doesn't shine
That's what i learned with my Internet searches.
I saw it fit to assemble all the infos i got for the convenience of future user searches.
Now it's the turn of my own question:
do you know anything about the optical layout of this converter?
The very positive reviews i found made me think that's a seven elements construction, but the pictures i've seen show that it is too short to be a 7E.
If nobody has any reliable information about the optical layout, i'm asking the owner of this converter to "read" the reflections.
With modern coatings is not that simple, especially glass-to-glass reflections can be barely visible. It's better to do it in a room with a single lamp, and orientate the lens until the reflections of the lamp separate one from the other. Some will be small, other big. The colors will be different, that would help a lot, but some reflections would almost overlap, so a little care is needed.
Faint reflections come from a glass-to-glass surface (glued elements). Glass-to-air reflections are stronger.
Once you learn how to do that, it isn't that complicate.
This is a trick that is known by all collectors of old objectives, but in the digital age got almost forgotten. Though it could be invaluable, if you need to identify the optical layout of an unknown lens.
With modern zooms it's almost useless, too many elements!
A side note:
there are almost no informations about the "optical recipe" of teleconverters. That's weird, cause the number of elements/groups of nearly every lens is known....
cheers
P
