I really appreciate the feedback.
From what I'm understanding, the Pentax 55-300mm is equal to (or better) than the Sigma 70-300mm APO DG Macro.
However, the Pentax will not be as useful for Macro shots.
I'm going to order the Pentax 55-300mm.
Its so cheap to buy a used copy that I'm confident that if I don't like it, I could always resell it.
Thanks again for the replies!
---------- Post added 06-03-14 at 08:41 AM ----------
Originally posted by Bob from Aus If you are happy with the sigma 70-300 you have no idea just how exceptional the pentax 60-250 is. They are worlds apart. While you might think that this pentax lens only goes to 250 my sigma 70-300 was very poor from 250 to 300. Yes it is more dollars, but the 60-250 should still be a coveted lens 20 years from now (if SLRs still exist)
I'm not upset with my Sigma from 250-300mm. Yes, it is a bit soft, but not soft enough to destroy any photos I take. Its still quite sharp.
I keep hearing about the Pentax 60-250mm. I will definitely try one out.
But they seem to be a bit too expensive.
---------- Post added 06-03-14 at 08:44 AM ----------
Originally posted by bluenose I was in a similar quandary with my Tamron 70-300mm lens in that the 55mm to 70mm gap from the kit lens was annoying at times. I picked up the Pentax 55-300 DA L and haven't regretted it. Image quality is on a par with the Tamron and focal lengths 18-55mm and 55-300mm are covered with no gaps. The Tamron was able to focus closer but to date haven't missed it.
Regards
Exactly. That gap between 55-70mm is really useful. There are many times I have my Sigma 70-300mm mounted and discover that I NEED to get down around 50mm.
---------- Post added 06-03-14 at 08:45 AM ----------
Originally posted by DSims If anything, the DA55-300 has better IQ than the Sigma 70-300, so there shouldn't be a problem there.
When I had the DA55-300 I thought having the 55mm end was very handy. It really helps when someone or a group comes closer to you than you expected, and you can still frame the shot.
Thank you. This was EXACTLY what I needed to know.
Originally posted by SpecialK All similar threads have ended the same way - the Pentax 55-300 IQ is better than the Sigma 70-300 APO DG Macro (the better of the 2 versions of that) and the Tamron 70-300. You lose the close focusing ability, however.
Thank you.
