Originally posted by Steve.Ledger I think the internal lens/elements tolerances are far more important than that first one.
The front element is critical in equalizing the angle of incidence with the angle of refraction. That's easy with primes, but is always a compromise with zooms, whick makes its alignment even more critical there. Check out Snell's Law if you're interested.
The question is, does it cause any observable abberation in this case? Only the OP can answer by doing some controlled testing.
I would try several shots on a tripod of a flat but textured surface (e.g. brick wall). Try some at close focus, some at midrange. The trick will be to hold the barrel at different "wobble" angles without introducing camera shake. Bright room or flash with high shutter speeds will help. It may get tedious, as the process should be repeated throughout the zoom range.
I don't expect that 1mm of travel will produce any discernable abberations in a focal length less than 100mm, but I could be wrong.
