Hi
I was thinking about the exif data when using a manual lens
The focal length you can set when you turn on with sr on but it is a problem that the camera doesn't record the f-stop.
Of course there is no way it can know or is there?
Pentax very cleverly designed the ka system to be compatible with the km to do this they designed a system of insulated and non-insulated contacts on the mount.
Basically 2 pins give the smallest f stop and 3 give the maximum
This works pretty well ka lenses with aperture rings have a pin that extends in A mode and the camera sets the aperture by moving a lever proportional to the fstop.
So what happens if we short the A contact?
well the camera now thinks its in A mode and trys to read the contacts but there isn't any contacts just the metal bayonet which means the camera see's 111A11 which is code for f22 - f1.2. In aperture priority mode and manual mode you can select the aperture you want to use sort off.
The km aperture lever isn't proportional to the f-stop so you are not going to get the f-stop set automatically correctly. chances are your lenses are not all f1.2's however you can manually set the aperture to what you want with the aperture ring.
So if you select f4 on the aperture ring and set f4 on the settings when the camera releases the aperture ring the lens will close down to f4.
Of course you could set the aperture to 1.2 and use the f3.5 maximum you actually have, that would probably fool 99% of people in to thinking you have expensive glass
I'm not sure what will happen with metering in Av mode will the camera adjust the shutter speed to the actual circumstances or assume its stopping down x number of stops from f1.2
Anyway at least now you will have the missing exif data and it will record what you say it is and hopefully you will set the aperture ring to what you said you were going to use.
I can not see a reason why you shouldn't keep the A pin set all the time. Every lens from a ka upwards will set it anyway, now all the km lenses will report an f-stop and its up to you to match it with the actual aperture you use. Even if you don't its still an improvement over f--
Ok so whats the problem with this? Pentax must have made the A pin for a reason. Is this going to break anything?
