Originally posted by Neville I would like some opinions as to whether the cost warrants the benefits of getting the prime lens.
You are talking apples & oranges. A consumer zoom and a 'pro' level prime. Only you can say if it is worth the money to you but the IQ will be noticeably better.
I used a 55-300 for several years and was very well pleased with it. It is an excellent lens in it's class. I moved up to the DA*60-250 and was stunned at the difference. The 55-300 is very good, the 60-250 is clearly and noticeably better. I don't have the DA*300 but the IQ with it should surpass the 55-300 easily.
The down side of course is that it is not as flexible and it is much bigger and heavier. But there are tradeoffs in everything, you just have to go with what works best for you. And as TER-OR says used prices hold up very well.
---------- Post added 06-04-14 at 07:31 AM ----------
Oh, and once you move up to DA* glass there is no going back, so consider the DA*300 as only a down payment on all the other glass you will need to match it...............
