06-05-2014, 02:28 PM   #1
DA 10-17 Lens Cap
I wanted to get a fisheye lens and jumped on the Rokinon 8mm for $199. Later that same day, I ran across a deal on a new DA 10-17 for $250. The lens was in the display case and is perfect except for missing the lens cap. Adorama and B&H sell the replacement lens cap for $40. Does anyone know where I can get a cheaper version for this lens?
06-05-2014, 03:08 PM   #2
EarlVonTapia's Avatar
You could just use a regular 58mm lens cap. The sides will be exposed, but not by much, and overall the front element should still be pretty much protected.
SGH-I747M  Photo
06-05-2014, 03:10 PM   #3
QuoteOriginally posted by EarlVonTapia Quote
That's pretty clever!
06-05-2014, 06:02 PM   #4
Sandy Hancock's Avatar
The spring loaded clamps on that lens cap must get dangerously close to the front element.
06-05-2014, 06:35 PM   #5
i found a soft pvc pipe cap end in the Home Depot plumbing section that fit perfectly over the front of this lens. Not pretty but cheap and functional
06-05-2014, 09:37 PM   #6
scole's Avatar
Get a Hood Hat from OP/Tech. I have these now for all my lenses except the 55-300 (I still use the wrap pouch that it came with).
06-05-2014, 11:23 PM   #7
I checked for that. It does come close, but a piece of paper is able to slip from one open side through to the other with no resistance, which I take as a sign that there is space between the front element and the cap. Also, the cap is quite sturdy, and I can't imagine it flexing, even in extreme heat.
Of course, I've only tested it with the cap I had pictured there. Your mileage may vary with other cap designs, Pentax or otherwise.
06-06-2014, 09:12 AM   #8
Just1MoreDave's Avatar
For my previous fisheye, I used three plastic-rimmed 67mm filters permanently slipped over the outside, then a 67mm cap. That works on the Zenitar also. They worked so well, I forgot to remove them when I took some shots with my film camera. The DA 10-17 exterior diameter is something less than a 62mm filter opening. I have a short metal 58mm thread hood with a 62mm opening that slips over it. I think that would work OK with felt lining and a cap on the end.
06-06-2014, 11:29 AM   #9
Thanks for the suggestions.
Does anyone know if this will work? B+W #300 60mm Push-On Lens Cap 65-030522 B&H Photo Video
06-06-2014, 12:49 PM   #10
THoog's Avatar
QuoteOriginally posted by mico Quote
It probably will work. The outside diameter on my 10-17 is right at 60mm, and I found a comment on flickr from someone who is using that cap on the Tokina version of the 10-17. The Tokina also has a built-in petal hood with 58mm filter threads on the inside (a fairly unusual feature), so if the hoods aren't from the same mold, they are very similar in dimensions.
06-06-2014, 01:49 PM   #11
QuoteOriginally posted by THoog Quote
Thanks. I just ordered this item and I'll update the post after I receive it to let you know if it fits.
06-13-2014, 11:55 AM   #12
Received the cap today and it fits perfectly!
cap, da, da 10-17 lens, k-mount, lens, pentax lens, slr lens
For Sale - Sold: Pentax DA 10-17 fish-eye lens - Price Drop cheehee Sold Items 6 06-15-2012 07:58 PM
For Sale - Sold: Pentax K200D, DA 18-55 I, DA 18-250, DA 10-17, Sigma 17-70, M42 to K adapter, rpriedhorsky Sold Items 20 11-07-2009 11:29 AM
DA 10-17mm Fisheye lens cap questio amaurosis Pentax SLR Lens Discussion 13 08-29-2009 12:14 PM
All times are GMT -7. The time now is 06:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
