Originally posted by CreationBear I've got a K-series 28mm F3.5 coming from a vendor soon, so I'm curious about what hoods and/or polarizer filters you find work well. My ideal I suppose would be to use a 52-49mm step-down ring so I can be compatible with my other filters/hoods, but I'm not sure how much vignetting I'll get.
Any thoughts appreciated.
The SMC(K) 28mm has a 52mm filter ring. On a film camera (Full Frame), a 52-49mm step-down ring will cause alot of vignetting. On a dSLR, I imagine a step-down ring will still cause vignetting.
For my SMC(K) 28/3.5, I have used a round 52mm 'wide' metal hood which still caused vignetting. I have recently purchased a K-series 'wide' retangular hood to use on it instead, and on the SMC(K) 35/2.0 [see edit]. With my film cameras, 28mm lenses* and no filters, I still get some vigetting with the round 'wide' hoods, which I have to crop out.
I think the new round 'wide' metal hoods are designed for crop-sensor cameras and are too deep to use on Full Frame.
[edit 6/10/2014]:
It has arrived, and the "K-series 'wide' rectangular hood" I just bought is a PH-52, and therefore is the correct thread size for my SMC(K) 28mm & 35mm lenses.
The silkscreen markings clearly state:
52mm
SMC Pentax 1:2-3.5 28mm 35mm
[end edit]
*for example
SV & SMC-Tak 28/3.5
K2 & SMC(K) 28/3.5
