Originally posted by glasbak Looking at the cut through picture of the K5 made by Falc Lumo, the K5 sensor glass and IR/antialias stack looks about 3mm thick !
Probably right.
Hereīs a follow up on the topic:
LensRentals.com - Sensor Stack Thickness: When Does It Matter? Originally posted by roger Cicala: Using Lenses on an Adapter
The practical importance comes when we want to use a lens designed for one camera on a different camera. (I’m assuming the adapter contains no optics itself.) Several factors come into play here.
1) The difference in sensor-stack thickness between the camera the lens was designed for and the camera actually being used.
2) The maximum aperture of the lens. Wide-aperture lenses are going to be more sensitive than narrow aperture lenses.
3) How telecentric the lens is. (More specifically, how far forward the exit pupil of the lens is.) A lens with the exit pupil far away from the sensor is not affected by the thickness of the sensor stack very much. A lens with the exit pupil very close to the sensor is affected a lot.
The exit pupil is an optical phenomenon – the exit pupil is not the physical location of the rear aperture or the rear element. It can be measured, but those measurements aren’t readily available. In general more telephoto lenses have very forward exit pupils and aren’t affected by sensor stack thickness very much. Wide-angle lenses may have very close exit pupil distances. Reverse-telephoto design wide-angle lenses (SLR lenses basically) have the exit pupil more forward than Rangefinder wide-angle lenses, generally.
So in theory, a 135mm f/4 SLR lens isn’t going to care much about the sensor stack thickness. A 24mm f/1.4 rangefinder lens can be hugely affected.
In the case of Pentax DSLRs, Exit Pupil distance should be at least the register distance of 44mm and later thereīs a table that says the Pentax 50mm f/1.4 Super Takumar has an exit pupil distance of 70mm.. Not that bad.
Also, there are few fast Pentax lenses so, another "migitator" of the problem
. And finally, legacy lenses are made for a bigger format than the one used on DLSRs so we donīt see much of the problems of the sensor stack, as they increase as you get further from the center of the image.
Originally posted by Bruno Masset: The further from the image's center (where the principal ray is perpendicular, and the cover glass has thus essentially no influence), the worse the image quality will be.
From
The Online Photographer article
Thinking out loud: The DA23/2.4 and DA50/1.8 where redesigned to take the sensor stack into account or just had their maximum aperture restricted to hide the sensor stack effects?
