I am sure that the matter (as per post title) has been discussed before. After giving it a thought, i came to the conclusion that the subject could interest many of us, so i decided to go specific, and ask your opinion about the availability of high quality alternatives to the f/2.8 zooms which dominate the prosumer market.
First let's try to explain what i'm thinking.
With film cameras you had the need for fast lenses, to avoid camera shake in low light, or at least to avoid using extremely grainy super-fast films.
Recently the performance of current digital sensors allows to shoot at very high ISO values, without too badly affecting the quality of the image.
It is true that fast lenses can be used to isolate the subject and blur the background, but personally i prefer to use very fast primes to achieve that effect (with even better results, cause i have primes which are faster than f/2.8). Basically, a 50mm "normal" from the film days would do...
Unfortunately fast primes fill up the bag rather quickly, if a good range of focals is needed.
In my case, size and weight are even more important, cause >90% of my pictures can be broadly defined as "travel photography".
Until very recently, most of my lenses consisted in manual focus primes. Then i moved abroad, and i could restart traveling, so i realized that the best outfit for travel photography consists in a few high-quality fast zooms.
After buying a couple of new (second hand
) zooms, i'm not so sure anymore.
F/2.8 zooms are heavy, or at least quite bulky!
My doubts are reinforced by my recent experience: i shot plenty of very low light pictures, using two old zooms with average max aperture, from the old days of film cameras!
I would be OK with them, but one is plagued by fringing, the other isn't very sharp (at least not below F/8).
With all that in mind, i asked myself a simple question: are the zooms currently marketed in PK-AF mount, in tune with the new reality (sensors/electronics with good high-ISO performance)?
My knowledge of new digital equipments is limited, from what i found thirds party offerings didn't keep up very well with the changing reality.
The high-quality zooms are still the f/2.8 ones, like in the analog days.
Pentax seems to cope a little better with the new reality, but personally i find that the "originals" of higher quality are overpriced.
At a general level, not just brand specific, don't you think there is a lack of high-quality prosumer zooms, with slightly reduced max aperture?
F/3.5 or F/4 zooms would be smaller and definitely cheaper, and probably could be made with top level IQ, even wide-open!
Going more practical and less "philosophical", any suggestion about zooms already available second-hand, which could fall in the category of "high-quality/medium-speed"?
I am more interested in third-party brands, i found that Pentax kit/amateur lenses are quite cheap, but the high-quality ones can be REALLY expensive. Out of reach for me.
Personally i am not very interested in high-cost stuff, and i try to stick to a simple rule: allow myself to try new lenses, but at the same time try to avoid stuff that nobody wants, or pay more than what can be easily gotten reselling the item
At the moment i am considering an AF zoom in the 70-200/80-210mm range, or maybe also a 100-300 or 150-400.
I didn't check very well, but i couldn't find something equivalent to the fixed apertures zooms from the early days of Pentax lenses with electric contacts.
For example like the Pentax-A 70-210mm F/4 i own (or like the Pentax-A 35-105mm F/3.5, different zoom range but still an outstanding zoom with fixed max aperture!).
I am open to specific suggestion, but i'm even more curious about what you think, on a more general level.
ciao
Paolo
