Originally posted by TonyTurley Finally, there's the option of the DA* 1.4TC WR. I'm just not certain how well it would work with my 55-300 WR. If my math is correct, that would give me 77-420mm, but at a slower f5.6-8. To sum it up, my questions are:
1) Has anyone spent much time hiking long distances with the Bigma?
2) Has anyone used the new 1.4TC with an HD 55-300WR?
To me the TC is the obvious starting point for this discussion. I doubt it will give you amazing results with your 55-300, but it should be good enough. Maybe ask a store if you can test it.
Originally posted by normhead I've spent lots of time hiking with a DA*60-250, it's heavy enough.
To me it's quite possible (and I'd say easy) to carry the 60-250 while hiking. It depends on what else you carry... I have no problems having the K-3 and 60-250 on my shoulder for a few hours (with a neck strap) when walking around, so having the same package attached with a good system (holster, case, etc) would be easy for me. What I'd probably do is place everything in my hiking backpack, carry a monopd in my hand and mount the setup as needed.
I've carried much heavier stuff than that before. But then again I purchased a well-fitted backpack.
That being said, I think most of the time when hiking I'd rather carry the 100 macro WR and crop as needed.
