Originally posted by bdery
Hi. Thanks for the link. I am actually referring to the FA, not the DFA or WR variants. Cheers.
---------- Post added 06-11-2014 at 07:36 PM ----------
Originally posted by jddwoods
. If you are looking at 100 mm macro I recommend the DFA 100 WR. I give it a 10. You may be able to find a good used one on the marketplace here or KEH.com if you want to save some money on it.
Hi. Thanks for your inputb, but I was actually referring to the FA variant. Cheers.
---------- Post added 06-11-2014 at 07:42 PM ----------
Originally posted by Doundounba
The Tamron is a superb lens. Where I'd hesitate, personally, is between the Tamron and a non-WR D-FA, at around the same price. But I'd pick a new (400g) Tamron over a used (600g) FA anytime...
Hi. I'll definitely give this serious thought. Thanks a lot.
---------- Post added 06-11-2014 at 07:45 PM ----------
Originally posted by xinanbei
I will pick up an used lens, just because when considering resell, you wouldn't lose much
Hi. As I mentioned earlier, the price is almost the same, which makes the used Pentax seem a bit too expensive. Thanks.
---------- Post added 06-11-2014 at 07:48 PM ----------
Originally posted by savoche
No quick-shift on the FA either, I believe. The DFA has, though. But at least you don't have to switch the lens to manual. Switching on the body will suffice.
I suppose it pretty much boils down to the hassle of the AF/MF switch on the Tamron versus the lack of a focus limiter on the Pentax.
I think I would go for the Pentax, too. Actually, I sort of did already, having the DFA 100
Hi. I shoot manual focus most of the time, even with my AF lenses. Thanks.
