Originally posted by goubejp The 55-300 is not fast enough for the converter. You must consider that the 2X converter will transform it to a f11.4 lens wide open. Good luck if you are able to focus it properly.
I have a Sigma 150 - 500. At 500 mm I usually set the aperture to F 10....F 11. I'm usually taking pictures outdoors during the daylight hours. Using my 2X on a 55-300 would make it a 600mm equivalent. F stops of F 10 F 16 for outdoor photos are not an issue...for me...or many other photographers I would think.
F stops of say...F 6.3 to F 8....on my Sigma @ 500mm I find really limit the depth of field. I like good DOF . With my K-5, using my Bigma @ 500mmI find F 10 + at 800 -1600 ISO....gives me very good shutter speed and the lens is still hand hold able.
Good pictures at higher ISO's that modern cameras can provide, takes away a lot of the disadvantages of F stops of F 10 +....IMO.
