So like many on here I suspect I have 1-200 photos on negs and slides that I would like in the digital domain. I have a multifunction scanner/printer by Canon that could theoretically scan them but it's slow, tedius and after importing them every single one would require cropping etc because such devices are really optimised for A4 etc not tiny negs aren't they?
I stumbled across someone extolling the virtues of using a DSLR to copy them - no cropping, manageable file sizes and miles faster than scanning:
The other way to scan positive slides, or, why I kept my big DSLR by Stefan Schmidt | STEVE HUFF PHOTOS
This loks like a good way to go to me, but the question is what lens to use.
I have an old Tamron Adaptall 80-210 F3.8-F4 manual lens with a macro mode providing 1:2.8 macro ratio and it occured to me that with a £30 secondhand Pentax or Tamron 2x teleconverter I would get up to 1:1.4 macro ratio which would enable me to fill the APSC frame with a full frame slide/negative wouldn't it?? (Given that the full frame neg is 1.5x the size of the APSC sensor)
Alternatively I have ordered £10 worth of extension tubes off Amazon and could try those with the 50mm F1.7 SMC-M lens I still have or even the DA 18-55 WR or DA17-70mm but I have no idea what ratios of macro these might give me on my K5 (they're 9mm, 16mm and 30mm) or how well this might work and would welcome views.
I also thought of buying a a device like this:
http://www.eos-magazine.com/articles/viewfinder/slidecopying.html The Ohnar slide duplicator but it's £100 new and contains optical glass which may or may not be any good and I can't help thinking that something like a £10 extension tube on my 50mm F1.7 could end up giving better quality.
Perhaps my biggest issue is how to mount/light the slide and that's where something like the Ohnar is ideal and I would really like to be able to buy a mount like the Ohnar has and put it on a second tripod...
Anyway, I'm guessing there's a lot of people on here with a whole load more macro experience than I have (and macro is something I'm rather keen to try now the flowers are out here) so if I can get something that will do the job while also opening up the world of macro photography that would be even better. If I really enjoy it then at some point in the future I might put down the money for a dedicated macro lens.
So fire away with your thoughts!!
Jonlg
