05-04-2008, 03:59 AM   #1
50mm 2.8 Macro Focusing problems
I was trying to manually focus the lens on my Samsung GX-10 ( K10D), but the focusing ring dosnt actually move. Well it moves sometimes, but not all the time.
My question is, should i change the focusing on the camera to Manual, ( MF) because the booklet that came with the lens dosnt say. I know that i have to move the clamp swith to On, but apart from that, it dosnt seem to work properly.
Thanks
N.Stocks
05-04-2008, 04:48 AM   #2
creampuff's Avatar
Do yourself a favour and read the camera manual first.
If you're gonna use manual focusing, you need to switch the focus mode lever on the camera body to manual focus to disengage the AF motor or you risk causing damage to it.
Which 50mm macro lens are you referring about? If it is the DFA, which has Quick Shift, you can turn the focusing ring even in AF mode. If you refer to the F or FA versions, you should not turn the focusing ring manually until you set the focus mode lever to manual focus.
The Clamp Switch is used for manual focusing. When set to ON, rotation of the focusing ring is tight. This helps prevent the rotation of the focusing ring due to the lens's own weight when pointed downwards and avoids any shift in focus. For normal or AF use, this switch should be set to the OFF position.
05-04-2008, 07:59 AM   #3
I thought it was that.
Ok, i have switched the clamp to ON, and manually focus on the camera.It still dosn't turn all the time.If i turn it right then it normally moves, but then when i turn it left it dosn't ' catch' and therefore dosnt turn.
N.Stocks
05-04-2008, 11:36 AM   #4
Should I send it in to get repaired?
50mm 2.8 macro, k-mount, lens, move, pentax lens, slr lens
focusing problems on k-x markjbamber Troubleshooting and Beginner Help 11 08-17-2010 01:36 AM
For Sale - Sold: 50mm Lens and Macro Focusing Teleconverter Youngster Sold Items 4 09-29-2009 07:00 AM
Pentax-M f1.4 50mm on a K20D focusing problems CraneGuy1 Pentax SLR Lens Discussion 22 08-30-2009 05:27 AM
Sigma 18-50mm F2.8 EX DC MACRO AF problems on K20D akptc Pentax SLR Lens Discussion 3 09-04-2008 05:44 PM
Pentax 50mm Macro Lens Problems N.Stocks Pentax SLR Lens Discussion 12 03-30-2008 02:02 PM
All times are GMT -7. The time now is 08:57 AM. | See also: NikonForums.com, part of our network of photo forums!
