Originally posted by 6BQ5 I'm thinking of picking up a DA 40mm XS lens. Some threads on the forum here suggest that the lens creates a FF image circle. The corners may be a little soft though.
Sure it does cover the full 35mm circle - here is my thread where I posted several photos taken with Z1p and the DA 40mm XS lens . It worked flawlessly and gave very good results. Wide open perhaps there is sort of softness in corners and extreme edges - but stopped to 5.6 lens in my opinion is uniformly sharp.
NOTE: That I had problems with scanner calibrating so some of the shots presented have bizarre white balance - this is only because of scanning process - I have rescanned them since then and they are absolutely fine.
Horses - SMC DA 40mm XS on Pentax FF with Kodak sensor ,,, '>' manntax
---------- Post added 06-17-14 at 03:22 PM ----------
Originally posted by 6BQ5 I'd like to use the lens on a modern-ish film body with Av mode in order to control the aperture. Has anyone tried this? Or, would I be stuck at f/2.8 on any film body?
Answering your question of course you would be stuck at f2.8 in AV mode on MZ-S and other bodies that don't control the aperture from the body on lenses without aperture ring. Worked superb on Z1p though.
,,, '>' manntax
