03-08-2018, 10:11 AM   #31
QuoteOriginally posted by stargazer Quote
Hi ,
I recently bought a takumar 500mm 4.5 and it seems that it was dropped during delivery. the Focus part of the lenses is rotating 360 an it wobbles back and forth for about 3 to 4 mm . I need to disassemble the lens and would like to know if someones has a guide that would greatly simplify the task and more important help me no to ruining this beast of a lens!!! Thanks in advance.
EXACT same thing happened to me - damaged in shipping and has the same problem. After reading through this thread and scouring the internet, I don't know which screws to start with! I don't know how the OP got their Takumar 500 4.5 torn down this far. Where to start anyone?
03-08-2018, 11:34 AM   #32
QuoteOriginally posted by vyoufinder Quote
hi vyoufinder, to take the tankumar apart its fairly simple, in the first page of the post you have an exploded view of the lens. You just have to start from the bootom up i think if its the problem lies in part nb17 the three screws are broken and need replacement. Do you have the K mount or M42 version?
04-06-2018, 06:06 PM   #33
Takumar 4.5 500mm - need Nikon F mount
I have a Takumar 4.5 500mm - with an OM1 mount but I need a Nikon F mount.
Are Nikon F mounts available for this lens?
Thank you.
09-12-2019, 03:39 AM   #34
Similar issue here, the entire focus ring section was wobbling due to a broken screw. Probably caused during shipping due to poor packaging. I had to disassemble and the lens, had to drill and had to find screw replacement.
At first, it seems impressive, but it is surprisingly easy and simple with the right tools.
Anyways, thank you guys for this topic and your insights, it helped me to fix the problem rather than to send back the lens.
ILCE-7M3  Photo
ILCE-7M3  Photo
ILCE-7M3  Photo
09-13-2019, 02:20 AM   #35
Apart and together again LIKE MAGIC...????
09-13-2019, 09:37 PM   #36
Absolutely !!!
It is funny how one screw can alter the entire feel of the lens.
Now that it has been reassembled, it does feel LIKE MAGIC, haha
09-09-2020, 08:22 PM   #37
Takumar 500mm 4.5 Focusing Section Wobbles
Hello, I guess I have a common problem. I've got a used lens that needs some attention: the whole focusing section slightly wobbles (similar to what you described). I understand that I need to go from the bottom up.
How exactly do you guys start? I removed the three set screws from the focusing ring (#20) and assumed it would slide off, but it did not. This is my first time disassembling a lens so forgive my naive question.
Many thanks.
500mm, degrees, diagram, diaphragm, guide, guide for takumar, intact, k-mount, model, models, pentax lens, post, repair guide, slr lens, takumar, takumar 500mm, takumar 500mm 4.5, tools, wobble
Takumar 500mm f/4.5 - FD mount? kirks518 Pentax SLR Lens Discussion 5 03-25-2014 10:37 AM
super takumar 500mm f/4.5? daverowe Pentax SLR Lens Discussion 19 12-25-2010 05:44 PM
Nature takumar 500mm f/4.5 first shots!! daverowe Post Your Photos! 9 12-25-2010 06:56 AM
500mm f 4.5 (Takumar) pntxjack Pentax SLR Lens Discussion 5 03-16-2009 04:36 PM
500mm 4.5 SMC Takumar? rdrum76 Pentax SLR Lens Discussion 3 10-30-2008 08:12 AM
All times are GMT -7. The time now is 11:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
