Hi all,
I will be looking for a walk-around lens that will complement my two current primes, the DA14 and recent purchase of a Voigtlander 90mm APO for my K-01.
I plan on getting a fast ~50mm at some point (Voigtlander 58mm most likely) but I want something that is relatively light, compact and SHARP as a walk around lens first.
I have owned a FA 20-35mm f4 lens previously when I had a K-7 a year or so back but sold it along with the FA43/K-7 combo as I went over to a Sigma SD15. On the Sigma I tried a number of lenses, including a Sigma 20-40mm f2.8 EX and 28-70mm f2.8 EX but quickly sold them on due to their size and weight (~700g/each).
I also tried the kit Sigma 18-125mm but its was pretty dreadful in build and sharpness..
Now, I will be looking to get something to bridge the gap between ~28mm and ~50mm (equivalent) and the FA 20-35mm seems the best way to go.
I liked the FA20-35 as it was very light although with sturdy but very plastic build. It was also very sharp but had quite a lot of distortion on the wide end.
The obvious newer competitor is the DA16-45mm but it seems a lot bigger, bit heavier and not as well rated on the reviews.
The Sigma options like the 17-50mm f2.8 are also bigger and almost twice the weight.
Unless I am missing something, I cant find any options that are as compact, light and sharp as the FA20-35 without going for separate primes (DA21, DA35 etc). Its also getting hard to find the FA20-35 these days too.
Oh budget would be up to £300, the newer 20-40mm Limited is way out of budget.
