Originally posted by torontoem4o It's safe to assume that all old lenses would be equivalent to a longer focal length due to the crop factor, right?
Uh, lets be clear here. No, they won't be. The field of view will be equivalent to a longer focal length. So a 50mm lens from 1950s and the brand new DA 50mm f1.8 have the same focal length and field of view on your camera. The thing is, if you put these lenses on an old film camera, the field of view will change - become wider. The DA 50mm already looks like a longer focal length on your camera. Just forget about equivalence - if you are using only one camera it doesn't exist. Equivalence is so that people who know what a 35mm lens, for example, looks like on film cameras, can visualize how it would look on a crop sensor camera. So, focal length of the lens doesn't change, but the field of view depends on the size of the film/sensor, so it can be "cropped" and made to look equivalent to a longer lens on a bigger film/sensor. All lenses are already cropped on a crop sensor camera.
The other thing is, 35mm was considered wide angle. These days, on crop sensor cameras, its not really wide angle anymore. 28mm was really wide, and 24mm was ultra. On crop sensor cameras, even 28mm isn't very wide. You can find many legacy 28mm and 24mm lenses, though. But wide angle lenses are very complicated and modern computer-aided lens designs with modern machining and lens coatings have come a long way. I suggest you look for lenses in your local area, and when you find some, check them in the lens review database on this website:
Pentax Lenses - Pentax Lens Reviews & Lens Database
You an also scroll down and look at film era Pentax lenses and start from there. I suggest you try finding a lens with A mode on the aperture ring, it will be much easier to handle.
