06-28-2014, 03:54 PM   #1
Daniel Darko's Avatar
Would this Leica Bayonet fit my K-mount?
Would anyone be able to help me figure if this lens would here would be compatible (read fit and a distance from the focal plane that is workable) with a K mount.
Jupiter 9 2 85mm Automat Lens FIT Kiev 10 Kiev 15 Camera | eBay
Jupiter 9 2 85 Black Kiev 1 5 Contax 7100352 | eBay
The 2nd one was another I found but I think that has an M39 moundt?? /shrug/
Thanks
06-28-2014, 04:53 PM   #2
My understanding is that kiev mount requires modifications to put on PK. registration distances - see
http://www.graphics.cornell.edu/~westin/misc/mounts-by-register.html
However usually these Russian lenses in M39 are no problem: although the mount is M39 the registration distance is = M42 .. = PK! So all that is needed is a cheap M39 to M42 adapter (then M42 to PK).
06-28-2014, 07:56 PM   #3
Otis Memorial Pentaxian
Neither of those lenses can be adapted to Pentax K. The first was made for the Kiev 10 Automat SLR camera and will only work with that and similar cameras (no aperture ring). The second is a rangefinder lens made to fit the Contax/Kiev mount rangefinder cameras and has a much shorter registration distance (34.85mm) than the SLR versions of the Jupiter-9 (45.46mm).
Here is my Kiev 4A mounted with a Jupiter-9.
The only Jupiter-9 that can be adapted are those in M42 screw mount and M39(Zenit SLR). M39(Zenit) is not the same as M39 (LTM rangefinder). You can tell the difference because the SLR lenses all have a pre-set aperture mechanism while the rangefinder lenses have fully manual aperture.
(...has Jupiter-9 in both Contax/Kiev mount and M42...)
07-01-2014, 11:50 PM   #4
Thanks. I was wondering about that as further research I did showed the registration distances to be unworkable.
Steve, are you saying that if I were to find an SLR version with M42 or M39 mount to adapt it would only be able to operate at max aperture without performing some kind of modification?
ie. https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/51749-m42-a...ification.html
07-02-2014, 07:25 PM   #5
QuoteOriginally posted by Daniel Darko Quote
All M39 (Zenit SLR) FSU (former Soviet Union) lenses have preset or manual aperture mechanisms and should adapt (requires two adapters) without modification to the lens. With M42 FSU lenses, the picture is not as clear-cut. In the case of the Jupiter-9 in M-42, there is never a problem with aperture stop-down since all SLR versions have a preset aperture mechanism (one ring to set the f-number and a second to do the actual stop down) and don't require coupling from the body to stop down. It is the auto-aperture lenses (coupled to the body via a small pin to stop down at exposure time) that may require attention.
Almost all auto-aperture M42 lenses have a switch on the side (M/A or Manual/Auto) that allows the aperture to function as fully manual (stopped down all the time). Those with the switch adapt with no additional work needed. This is not true for many FSU M42 lenses and a few other non-Soviet lenses as well. No switch means that the lens stays open all the time when adapted to a K-mount body. Fortunately, this problem can usually be resolved by a small bit of reversible surgery on the mechanism to make it stay stopped down all the time.
07-03-2014, 10:23 AM   #6
I'm relieved to hear that. I've been having a look at the pictures put out by some of these old Russian lenses - in particular the Jupiter 3, and they really impart their own unique feel.. I've read some people dismissing such artefacts as qualities of a bad lens, but I think there's something to be said for a picture that doesn't look like it's the immaculate conception of LIghtroom. Sharpness isn't the only measure of a good picture!
I'mma just keep researching and spending all my free time looking for lenses on ebay like a crazy person. Once I get some solid lenses in my swag, I'll be coming back for the Russians. I'll just be drooling over the photographilia on ebay til then
I WANT I WANT
07-06-2014, 03:37 PM   #7
MJSfoto1956's Avatar
the only M39 lenses that will provide infinity focus are those that were made for the Leiva Visoflex system. Google Visoflex M39 -- there is lots of information available. I have a couple of Visoflex lenses and some are quite decent.
M
ebay, jupiter, k-mount, kiev, leica pentax mount, lens, pentax lens, slr lens
Old K mount lens won't fit on my k-r body Timelime Troubleshooting and Beginner Help 10 02-10-2013 01:02 PM
HOYA HMC 75-205mm K mount does't fit my K100D super Evostic Troubleshooting and Beginner Help 2 08-29-2012 02:36 PM
Konica Bayonet Mount Lens fit Pentax? Take-5-JB Pentax SLR Lens Discussion 3 10-27-2010 07:41 AM
Old K mount lens would not fit! dbh Pentax SLR Lens Discussion 18 12-13-2008 09:45 PM
Will this fit my K10D mount? (I can never remember) doggydude Pentax SLR Lens Discussion 3 05-16-2007 11:04 AM
All times are GMT -7. The time now is 10:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
