05-05-2008, 11:24 AM   #1
18-55 vs 18-55 II
i read that there are two 18-55 versions:
- 18-55mm (old)
- 18-55mm II (new)
there are differents? II version is really better?
05-05-2008, 11:27 AM   #2
the optical constructions is different, version II is better
see this posting, unfortunately the pictures don't show
DA 18-55 (I) vs. DA 18-55 (II) on DS - comparison shots [Page 1]: Pentax SLR Talk Forum: Digital Photography Review
05-05-2008, 11:31 AM   #3
Banned
on paper its better, but will you notice a difference? maybe if you use 18mm often otherwise probably not. it does have a different lens cap though.
05-05-2008, 11:33 AM   #4
QuoteOriginally posted by k100d Quote
hello!
you are very kind! thanks for link ...but images are not available.
there is an online test about 18-55 II?
about you, the II version is good like 16-45?
05-05-2008, 11:55 AM   #5
can't really help you there, but i'd imagine the 16-45 is much better. however, the 16-45 blocks the built in flash at its widest point.
try searching in google for postings in dpreview about the 18-55 ii, there maybe be more
site:dpreview.com pentax 18-55 ii
05-05-2008, 12:00 PM   #6
PFH
PFH's Avatar
I previosly owned the old version,now i own the new mkII
As far as I can se the edge shapness is significantly better on the mkII, and so is the contrast.
05-05-2008, 12:20 PM   #7
i dont' understand here. what do you mean?
sorry, please can you tell me more info using other easy words?
05-05-2008, 12:23 PM   #8
KjetilH's Avatar
The lens extends when you zoom out to 16mm. Because the flash is mounted pretty low on the camera, you get a shadow in the bottom of the frame, caused by the extended lens barrel blocking the flash light.
The 18-55 is at its shortest as 35mm, and extends a centimeter or two either way.
05-05-2008, 12:23 PM   #9
Pentax SMC-DA 16-45mm f/4 ED AL - Review / Test Report
when the lens is at its widest (16mm), it needs to extend out very far. if you use the built-in flash at this focal length, the lens will block the built-in flash and you get a strange shadow. this is not uncommon for other lenses as well.
haha what KjetilH said :P
05-05-2008, 12:36 PM   #10
axl
vigneting?
QuoteOriginally posted by PFH Quote
Ok if sharpness is better, how is the vignetting? At 18mm in Mk I it's quite visible (the front element seems to be bit underdesigned) Does Mk II suffer from the same?
05-05-2008, 01:00 PM   #11
PFH
PFH's Avatar
I donīt think vigneting is a major problem
05-05-2008, 01:04 PM   #12
vey thanks for info! :-)
about you 16-45 or 18-55 II ?
05-05-2008, 01:15 PM   #13
PFH
PFH's Avatar
I own them both and I wonīt part with any of them.
I like 16-45 for is outstanding picture quality but itīs rather bulky.
I like 18-55 for itīs small size and relatively good picture quality.
05-05-2008, 01:32 PM   #14
I own them both and I wonīt part of any of them.
I like 18-55 for itīs small sice and relatively good picture quality.
about 16-45 i read that has a lot of chromatic aberrations.
do you know?
05-05-2008, 01:58 PM   #15
PFH
PFH's Avatar
OK thereīs some purple fringing with the 16-45, but again I must say I donīt think itīs a major problem.
To completely avoid the problem you might have to invest in star or limited lenses.
Once again Iīm not disturbed by the amount of ca with my 16-45 or even the 18-55.
18-55mm, ii, k-mount, pentax lens, slr lens
All times are GMT -7. The time now is 08:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
