07-08-2014, 04:38 PM   #1
pentax 35mm DA 2.4 lens hood and filter
Hey guys I had no idea that the 35mm 2.4 DA not the L version had no screw to mount a filter on. I bought a hoya filter kit and have no way to mount the filters. Please advise on what to get.
Also is there a hood that is compatible with this ?
07-08-2014, 04:48 PM   #2
Na Horuk's Avatar
QuoteOriginally posted by mellowyeahlow Quote
What are you talking about? There is only DA 35mm f2.4 and it has a filter thread with 49mm diameter. There is no L version, but the lens does have an AL in its name (meaning the lens includes aspherical elements - a good thing). It doesn't have a bayonet for a hood, but it has standard filter threads so you can screw on any 49mm filter or lens hood. I don't know what size filters/hood you bought, maybe they are too big (52mm?)
07-08-2014, 04:53 PM   #3
Nvm... I'm clueless... hahah. First filter ever. Sorry I'm clueless.
Ok.. so this can't hold a hood huh?
07-08-2014, 04:54 PM   #4
I don't have the lens but am looking at a picture of it and it appears to have 49mm filter threads.
Pentax has always been inconsistent in putting hood bayonets on lenses, and I'm not a fan of that. I don't even understand it from a marketing perspective, in that Pentax loses the opportunity to sell expensive pieces of plastic. It was true years ago and is still true now. There are ways to overcome that (the 28/3.5 SMCT hood design for example), but too frequently you're stuck with those annoying screw-on hoods.
07-08-2014, 04:56 PM   #5
Na Horuk's Avatar
It won't fit how? Can you maybe post a closeup/crop photo of the filter?
I mean, its a filter, you screw it on. Can you try putting it on another lens?
Btw, the DA 35mm f2.4 doesn't come with a hood. I don't know what kind of hood you are using. You can buy any screw-in hood for 49mm filter threads. You should buy one for a "normal" lens. Can be round, with petals, rubber or plastic, doesn't matter
Edit: Oh wait, are you talking about the DA 35mm f2.8 limited macro? This one has a built-in hood
07-08-2014, 05:00 PM   #6
I was an idiot. I didn't line the filter at a right angle so the threads would never line up. Sorry. I'm clueless. Hahaha
---------- Post added 07-08-14 at 05:01 PM ----------
And I'm pretty upset that this has no mount for a hood. This thing looks fragile
07-08-2014, 05:02 PM   #7
Na Horuk's Avatar
No worries Filters can be very fiddly, with the precise filter threads. Especially new ones might be a little tight to fit
07-08-2014, 05:04 PM   #8
Man this 35mm takes some sharp pictures. I'm in looooove
07-08-2014, 05:33 PM   #9
aremmes's Avatar
Post some pictures to the Plastic Fantastic lens club thread and browse those shared by others there. You'll find much to like about your new lens.
07-08-2014, 06:01 PM   #10
manacho2005's Avatar
Go out and shoot with it; you'll soon realize that you don't need a hood with that particular lens. The only time I get flare or low contrast is by putting the sun inside the shot...
07-08-2014, 06:57 PM   #11
ramseybuckeye's Avatar
The 35/2.4 takes a square spring mount hood (Plastic Square-edged Spring Type (PH-SA49)), the same hood fits the various 50s. It's expensive when Pentax has it, but a Chinese knockoff is still $11 and up on ebay. I have one of these and one spring sticks sometimes so it tends to fall off. I have switched to a metal screw mount hood that has a lens cap fitting the end of it.
07-08-2014, 07:07 PM   #12
I use a knock off of the DA40 hood. Haven't noticed any vignetting.
07-08-2014, 07:41 PM   #13
OregonJim's Avatar
??? I use a hood on mine all the time - the one that goes with my A 50/1.7. It's a 49mm screw in hood. You could also use any of the generic rubber screw in hoods...
07-08-2014, 08:12 PM   #14
rbefly's Avatar
Actually, it does. A real mount, not two short, wide grooves like many modern lenses. The threaded hood mount hasn't been completely replaced as the best, most stable, versatile and secure attachment system and probably won't. It works perfectly with another grand old tradition, which you'll need to learn as well; The screw-in filter.
Threaded mounts are more secure, protect the lens better and are the rule, not the exception. Clip-on is only for hoods and not universally-used for that.
Budget primes and zooms usually don't include a hood, Pentax is no different there. But if you look carefully at any (clip-on-hood) Pentax lens, they all have additional threads for filters. All good lenses do, as far as I know.
The plastic fantastic is very tolerant of hood dimension, I use a 49mm 'wide-angle' metal type but have resorted to a 'standard' (straight tube) one in a pinch, no vignetting so far. The flare resistance is good without a hood, but I prefer using one anyway.
Good luck!
Ron
07-08-2014, 08:25 PM   #15
QuoteOriginally posted by filoxophy Quote
where did you get it?
35mm, da, da 2.4 lens, filter, hood, k-mount, lens hood, line, pentax 35mm da, pentax lens, slr lens
For Sale - Sold: Da 35 2.4 with Marumi Super DHG Polarizing Filter and Hood zbrueningsen Sold Items 2 05-09-2014 07:16 PM
For Sale - Sold: Pentax SMC 35mm DA F2.4 AL Lens with Metal Hood and cap goldenhawk Sold Items 2 07-21-2013 02:34 PM
DA 35mm f2.4 AL lens - My hood and cap solution LowVoltage Pentax SLR Lens Discussion 18 03-09-2012 10:51 AM
For Sale - Sold: Pentax Da-L 55-300mm f/4-5.8 with lens hood and uv filter (Worldwide) suzuki-j Sold Items 4 01-21-2011 11:05 PM
All times are GMT -7. The time now is 01:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
