05-06-2008, 02:19 PM   #16
Tom S.'s Avatar
QuoteOriginally posted by thear Quote
Using Windex and other window cleaning products will destroy the coating on the glass.
Not if the glass isn't coated. Like I said, I'm not using it on the lenses (or my polarizing filters for that matter), only the cheap clear filter I buy to protect the lens.
05-06-2008, 03:27 PM   #17
creampuff's Avatar
Isopropyl Alcohol
Let me suggest the method that is used in optical factories that is cheap and effective in removing fingerprints and other surface contaminants.
Use a piece of good quality tissue dipped in a little diluted Isopropyl Alcohol. Wipe the lens lightly and all the fingerprints will be gone in seconds!!! You can get isopropyl alcohol from most chemists or pharmacies. It is cheap and it works as the alcohol will evaporate quickly leaving no residue. Works on filters too btw and it does not damage the lens coating. I have used this for years and I know it works perfectly. And it also removes all the grease marks on the rear LCD too.
I find using a lenspen or microfibre isn't that effective because over time the material will have picked up the oily marks but it remains embedded in the material.
I personally avoid sprays used to clean spectacle glasses because the solution has an additive added to prevent the spectacle lens fogging from condensation. Don't know if it will affect the lens coating long term.
Glass cleaner is definitely a big no-no due to the chemicals added. I found very early on that Kodak lens cleaning solution isn't very good and leaves smear marks. The breath and microfibre combo isn't very effective either with oily fingerprints because you're just rubbing it in and not actually removing the mark.
05-07-2008, 04:42 AM   #18
gkopeliadis's Avatar
QuoteOriginally posted by Matjazz Quote
I use filters and seldom clean lenses with anything more than a blower.
First step taken : I bought some HOYA digital pro1 UV for my lenses...
05-07-2008, 05:10 AM   #19
Lowell Goudge's Avatar
For cleaning lenses, I would have to agree with creampuff.
If you can't use alcohol, just use your breath. I use lens cleaning tissues and a blower, but never a brush. As others have noted, brushes tend to pick up oils, and can also carry things that scratch the elements.
I also, like most, use filters, and therefore the need to clean anything with other than a blower, due to dust when changing filters, is minimal.
For filters I use the same process, but will, on occasion use lens cleaning solution for glasses. This is especially true if I am in a salt environment (sea shore) or there are stubborn marks.
05-12-2008, 07:21 AM   #20
Nesster's Avatar
I forgot about the LensPen - that's a real miracle product IMO, and easy to take along.
05-12-2008, 09:58 AM   #21
I'm not a filter user, but I frequently use a lens pen, and for finger prints and the like (pollen can be sticky too) I use methyl alcohol (methanol). Methanol is the the same as "Eclipse" fluid but much much cheaper. Use it with any microfiber cloth or pad. Works wonders on fingerprints, pollen, etc. I also use it to clean nose smuges from the rear lcd.
NaCl(good stuff methanol)H2O
05-12-2008, 11:00 AM   #22
TKH
TKH's Avatar
QuoteOriginally posted by metalfab Quote
I use a LensPen, one side has a fine brush for the dust, the other end has a felt-type pad for cleaning off smears, spots, etc. that might occur.
We are on the same road.
I never used a filter on my lenses. I dont think thats a good way to receive a very good image quality.
Best,
Rainer
05-12-2008, 11:49 AM   #23
ChrisPlatt's Avatar
People are so prissy about cleaning their lenses and filters!
I have never damaged a lens (or mirror for that matter) using conventional lens cleaning fluid.
We used Freon at Olympus; a very good repair person I know (who used to work at Pentax) uses Windex.
Usually I just fog the filter or lens with my breath and clean it with several layers of lens tissue.
My undershirt (Hanes) works just as well in a pinch.
Chris
05-12-2008, 11:51 AM   #24
and
kodak lens cleaning liquid and lens cleaning paper
05-12-2008, 01:50 PM   #25
Sandblasting and gasoline. Then a thorough wipe with an old dirty smelly sweat sock.
Seriously, here is a good read on Lens cleaning.
It's Lens Cleaning Time - Photo Tips @ Earthbound Light
One might want to have a read on sensor cleaning,
Sensor Cleaning: Where Is That Dust Hiding, and What Do I Do About It? - Photo Tips @ Earthbound Light
05-12-2008, 01:55 PM   #26
Gooshin's Avatar
a little personal breath and a microfiber cloth, no problems here.
if i happen to seriously dirty it up with an oily finger print stain, i just grab my dads eye glasses cleaner and use a bit of that.
05-12-2008, 02:10 PM   #27
Breath might contain food for fungus. Or fungus for that matter.
05-12-2008, 02:13 PM   #28
Gooshin's Avatar
QuoteOriginally posted by Zewrak Quote
about as much as the polluted air of a heavy metropolis, if not less...
05-12-2008, 02:13 PM   #29
Then eat something fresh before breathing on the lens.
05-12-2008, 02:15 PM   #30
Gooshin's Avatar
the way i see it, unless you keep your lens in a sandbox or an old gym bag, you have nothing to worry about.
k-mount, lens, pentax lens, slr lens
How to clean lens rustynail925 Pentax SLR Lens Discussion 11 04-25-2010 08:54 AM
Clean Pentax SMC Lens trevorgrout Troubleshooting and Beginner Help 8 04-17-2010 05:46 PM
Keeping the lens clean StarDust Pentax SLR Lens Discussion 10 02-22-2009 10:47 AM
what do you use to clean your lens? slip Pentax Film SLR Discussion 17 05-25-2007 01:07 PM
How do you clean up an old lens Alvin Pentax SLR Lens Discussion 3 02-19-2007 08:06 PM
All times are GMT -7. The time now is 02:55 PM. | See also: NikonForums.com, part of our network of photo forums!
