Originally posted by lytrytyr Same scheme, but the cemented join on the M is flatter than on the A.
These are the f/1.4, right? I was unaware, though it should not surprise me. The M, A, F, and FA 50/1.7 are all identical and I assumed the same for the f/1.4.
---------- Post added 07-14-14 at 09:54 PM ----------
Originally posted by axelm7 I just noticed the 1.7 jumps straight to 2.8, skipping f/2 altogether.
Most (all?) Asahi/Pentax 50mm lenses have click stops at intermediate points between the marked numbers on the aperture ring. For the M 50/1.7 the clicks are at f/1.7, f/2, f/2.8, f/3.5, f/4, f/4.8 (I think), f/5.6, f/6.7, f/8, f/9.5, f/11, f/13, f/16, and f/22.
Originally posted by axelm7 Yeah, price wise I think it is the best, and I just found a decent copy of an M 50mm 1.7 and it comes attached to an ME Super body. I've never used a 35mm film SLR before, might have to get some film and see how that goes!
Please do put that ME Super to work! It will likely need new light seals and mirror bumper foam, but that can be done as a DIY project. The good folk on the film slr section of this site are very helpful.
---------- Post added 07-14-14 at 10:08 PM ----------
Just for completeness, here is a macro taken with my M 50/1.7 on bellows. The reproduction ratio is about 2:1 and the subject is the petiole of a small vine maple leaf. Note what is probably a fungal filament on the side of the stem. Also note the very shallow DOF at that magnification. I think this was taken at f/16.
...and a 35mm film shot at portrait distance with the same lens (~f/8):
---------- Post added 07-14-14 at 10:24 PM ----------
Originally posted by pinholecam The 'wide open' criteria is a bit hard to tie down.
Some of your options are f4 wide open while others are f1.4 or f1.7.
The 50/1.7 has more even sharpness thru the frame from f1.7.
In the center area, I never found it to be sharper than the f1.4 at f1.7 (and I had all the 50mm f2,f1.7,1.4 in A and M versions as well as the FA)
This boils down to their lens design differences.
By f2.5, my A50/1.4 is very sharp in the central area, getting more evenly distributed sharpness by f4.
In summary :
Best bang for buck : M50/1.7 (on a budget, very few things can beat it, even my Rollei 50/1.8 can't; but hexagon OOF highlights by f4)
Best : M50/1.4 (spend that money once, get the most versatile one of the lot and be done with it)
Macro : Then you need a macro lens
A50/1.4 at f4 (I also left a very large copy on my flickr if you want to see how sharp it is)
A50/1.4 at f2
Nice work with the FF Sony A7! Are you sure about the aperture of the Grand Mother photo? Based on the DOF, I would suspect about f/4 or even f/5.6. For comparison, see my B&W 35mm film photo (probably f/8) above.
