07-22-2014, 02:25 PM   #1
The dog walker's Avatar
f-numbers for SMC 135 2.5 and 85 1.8
This may be a mute point, but I would like to know what the half stops between two lenses are. SMC 85-K 1.8: there is a half stop between 1.8 and 2.8, does anyone know what f-number that would be ... my guess is f2.
And on the 135-K 2.5 lens there is a half stop between 2.5 and 4 and my guess is that it is either f3.5 or 2.8.
I realize that this is not going to affect my metering that much, but I kind of would like to know just the same.
Thanks for whoever answers this,
Cory
07-22-2014, 02:46 PM   #2
Imageman's Avatar
f numbers hop by double alternately.
1.4.....2.8.....5.6.....11.....22
.......2.......4........8......16.......32
The natural progression is therefore f1.4 f2 f2.8 f4 f5.6
I see f1.8 as a half stop oddity that manufacturers used to give a slightly wider aperture than f2 would have.
Your conclusion is I believe a reasonable one
07-22-2014, 02:51 PM   #3
1.8 should be a third of a stop below 2, and 2.5 a third below 2.8 (full stops being 1.4, 2.0, 2.8 and 4.0). As such, you really can't set a half stop away. I believe if you've set your camera to half stop increments, the aperture will first move a 1/3 rd the nearest full stop, then move in half stop increments. If you could move in 1/6th increments you could get there (1/6th from the full stop, or about 2.1 or 2.2 for the first, and about 3.0 for the second).
07-22-2014, 02:52 PM   #4
gofour3's Avatar
QuoteOriginally posted by The dog walker Quote
Cory
For the K85/1.8 the unmarked click is f2.4. (So it's f1.8, f2.4 then f2.8)
For the K135/2.5 the unmarked click is f3.4. (So it's f2.5, f3.4 then f4)
Pentax never used unmarked clicks as full stops.
Phil.
07-22-2014, 03:01 PM   #5
QuoteOriginally posted by gofour3 Quote
Phil.
After posting this thread I found your other remarks regarding the similar question, thanks Phil.
07-22-2014, 03:15 PM   #6
Paul the Sunman's Avatar
Strictly, a full stop is a factor of √2=2^(1/2) in f-number, half a stop is 2^(1/4)=1.1892, and a third of a stop is 2^(1/6)=1.1225. So, if you really do start at f1.8, the half-stop progression is 1.8, 2.14, 2.55,3.03, 3.6, ... (to 2 decimal places), and the one-third stop progression is 1.8, 2.02, 2.27, 2.55, 2.86, 3.21, 3.6, ... On the other hand, the neater and more likely 1/3 progression is 2^(n/6) (n=-1,0,1,2,...) which gives 1.78,2,2.24,2.52, 2.82, ... That is, 1.8 is really 1.78 and is a 1/3 stop down from 2. So, half way from 1.78 to 2.82 is 2.24 on this logarithmic scale.
07-22-2014, 03:20 PM   #7
Senior Moderator
Parallax's Avatar
07-22-2014, 04:17 PM   #8
gofour3's Avatar
From a Pentax lens guide:
https://www.pentaxforums.com/forums/attachments/10-pentax-slr-lens-discussion...2269.jpg?stc=1
Phil.
07-22-2014, 04:51 PM   #9
Lowell Goudge's Avatar
Cory
Every pentax lens I own even those which start at 1/2 stops is the same, first and last clicks are full stops, between these tow every other click is a 1/2 stop
135 85 f-numbers, f-numbers for smc, half, k-mount, pentax lens, slr lens, smc
For Sale - Sold: Pentax 135 f 2.8, 28 f 2.8, Tak 300mm f 4, 55mm f 2 and Pentax M 80-200 f 4.5 davidgreen3003 Sold Items 13 02-12-2014 04:55 AM
For Sale - Sold: K-5 + 18-135, 40 f/2.8 , 70mm f/2.4, 35 f/2.4, F50 f/1.7, 55-300 ED, Tamron 17-50. rrwilliams64 Sold Items 19 03-08-2013 07:09 PM
All times are GMT -7. The time now is 04:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
