A DIY lens experiment continues, and one of my investigations involve those novel pieces of machined aluminum, the reverse K-mount adapter. Like so many other accessories, these things are plentiful and cheap on eBay. The infamy of knock-off M42-to-K adapters for getting stuck on DSLR bodies makes me wonder if anyone has an opinion about the K-mount half of the reverse adapters. If any of you have had experience with the reverse adapters, can you say one way or the other if the K-mount portion has caused issues with your camera?
It seems the M42/K adapters have trouble with the small metal flap malfunctioning or some other thing (this leads me to believe if any of the third party adapters are any good). However, the reverse adapters don't appear to have the extra metal flap. Any issue with the precision of the mounting distance is less of a concern because these things are used for macro photography.
And while I'm on the subject of anything K-mount knock-off related, my eBay trolling showed me this
K-mount bellows. Naturally, they don't show the mount end of the bellows, so who knows what to expect there.
For what it's worth, I'll mention that the bellows could potentially be used in conjunction with the reverse adapter. Basically, I need a focusing method to move a "lens" made from loose elements and filter rings to-and-from the sensor plane. I'm considering some helical focusing extension tubes. Because these use M42 mounts I would need an M42/K adapter and I'm not willing to jeopardize my camera body with a knock off adapter. The real deal is either hard to find or ridiculously expensive. My experiment is getting more and more costly, so if I don't have to by the M42/K adapter at all then I'd be happy.
