Thanks for the insight fellas. THe mount seems like it might be an odd ball, here's what I found in a rec.photo.darkroom user group -
Quote: "I have a Componon 80/5.6 mounted on my old Durst M600, it has a 25mm
thread (if I remember correctly). If it's the same, you need a custom
adaptor ring to mount it on a 39mm.
Rgs"
"The one I had was a Durst branded Componon 80/5.6 this had a smaller
thread than 39mm. It used a special lens plate with smaller therad.
The plate had the same outer diameter as the ones with 39mm thread.
So it worked perfect.
But why not go for the Componon S 80/4 which has 39mm thread mount?
Darkroom equipment is so cheap now that you can get it for very little
money.
I switched from the 80/5.6 to the 80/4 and the extra stop was very nice.
If you use glass holders you can use 5.6 as your working apperture."
Mine doesn't say Durst or anything, so maybe its still 39mm... I'll check some more.
As for the mount choice, I think if I were to go with one, I'd definately look into the Zoerk MFS. Sells list for 549US including Pentax-K adapater and 39mm housing. But, there is mention of a model inclusive of the componon 80/4 for 899 mentioning the lens is adjusted for infinity...
Further, my copy of this 80/5.6 is broken. I opened it and the aperture (15-blade!!) is almost seized. Will need a good cleaning in Ronsonol when I get the time. Not sure its worth anything more than my duct tape housing for the time being, though its interesting to use it as is for free, for now, hehe.
Thanks again guys.
