Most lenses are soft (all are softer) wide open. Close down 1/2 stop and things (should) get much better. I think it is a mistake to expect otherwise. The wide open character may be interesting, but wide open generally allows you to focus more critically.
Maybe my 1/2 stop is a bit optimistic--although I have several lenses where I see this--but it it is often more about other lens attributes. Most lenses should get much better in sharpness by about 2-3 stops closed--as you observed. That is normal.
Throw enough money into the mix, make the lens large (so it starts out already [effectively] stopped down), limit the FL range, etc., and things get better--but such lenses are not a viable solution for most of us.
