The (small) risk i took in the end payed off.
Thanks to the advice i got from Dave (btw, thanks a lot, Dave!), the front part of the lens proved easy to dismantle. ALL the three glasses were covered by a net of fungal growth. Cleaning all that mess was not quick, and not as easy as other fungi i cleaned in the past. I had to dismantle the elements once more cause there was some "fog" left. The second cleaning session removed any trace of dirt. Fortunately the fungus didn't have enough time to attack the coating/glass surface, so now the lens looks and behaves like new.
I found a weird thing: the lens works as it should with a K-5 II, but doesn't pass aperture and FL infos to my K-10D. The AF is not working as well!
I didn't test the lens before opening it, but i didn't touch the bayonet flange and its contacts... so i guess it behaves the same way it did before.
While i was writing the previous line i thought it was better to double check: i took out my K-01 and tried the 70-210 with it. Perfectly OK.
The problem shows just with my K10D. Really weird, cause i tried another AF lens and the body focuses and shows the aperture, as it should and as it has always done...
Any clue?
cheers
Paolo
P.S.
If you're on a tight budget, and can't afford the best of the crop, don't be scared to bring back to life some old (or not-so-old) damaged optics.
Do your home work first, practice with a hopeless objective before tackling a valuable one, and use common sense. Even more important: buy cheap so the risk you take will be minimal.
There are a lot of satisfactions along the way, and probably a few disillusions. Just think that what was routinely done by the photographers of the old times can be done today... you just need to learn how to do it!
I recently bought 3 damaged/not working lenses. The Pentax-F zoom is fine, a recent Sigma 30mm EX DC is usable (but i will order the front glass to replace it, if i find how the hell the front of the lens can be opened!), and a wonderful Kino-made 28mm f/2 will have the diaphragm blades cleaned/fixed quite soon.
All of them were payed a fraction of their market value, no great risk involved....
