05-09-2008, 12:43 PM   #1
synnyster's Avatar
My DA* 16-50 Focus Test
Well, I received the 16-50 today from Buydig. Here is a shot with the focus chart. The chart I printed for some reason did not look straight. I added a straight line in photoshop for reference. It looks like it is decentered to the left and back focusing. What do you guys think I should do?
05-09-2008, 01:12 PM   #2
From what I've seen from the too bad copies I've had, you've got a keeper....at least in terms of focus...
Same test I could barely even read "this line should be in focus"
05-09-2008, 01:28 PM   #3
wlachan's Avatar
Doesn't look bad but really can't tell because there is a good chance the centre AF sensor might cover a wider area than the centre "focus here" line. Also, as the shooting distance increases, the AF error would be more obvious. Another way to test BF/FF is to shoot a sequence of some near infinity well defined target on tripod wide open with different um setting in debug mode. Pick the sharpest one then you will be able to tell how far off the original um setting was.
chart, da* 16-50 focus, focus, k-mount, pentax lens, slr lens
Need help regarding back-front focus test. marography Pentax DSLR Discussion 5 06-14-2010 03:34 AM
Need help with a DA*50-135 focus test. the swede Pentax SLR Lens Discussion 11 09-07-2009 09:40 AM
Focus Test Mallee Boy Post Your Photos! 9 08-30-2009 07:40 AM
K-7 with FA50/1.4 focus test? fulcrumx29 Pentax DSLR Discussion 14 08-14-2009 05:29 AM
What to make of this focus test? lavascript Pentax DSLR Discussion 19 08-06-2009 11:03 AM
All times are GMT -7. The time now is 06:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
