Originally posted by MrA Can someone with more knowledge of the mathematics behind optics clear something up for me. There are adaptors on the market accepting medium format lenses (e.g pentacon six), which fit cameras with a more current mount e.g pentax k. Companies like arsat make shift adaptors, for instance, which do this.
If one uses such a setup, are there any issues with focal lengths / lenses not reaching infinity, which are immediately going to be encountered, or does the existance of the product imply it will more or less "just work" if you attach one to the other?
I understand that lenses expect to focus on the sensor, which clearly would be in a different (but known) position for a mf camera to a aps-c setup.
There can be issues, if the adapter isn't made correctly. Your best bet is to check the FAQ of the manufacturers website (if there is one), or email/phone them to find out if they allow infinity focus. If never used them, but I would assume that the Pentax adapters for the 645 and 67 lenses would allow infinity focus.
Originally posted by MrA I'd also be interested to know what happens to the angle-of view if you use (say) a wide angle mf lens (say 40mm) on an aps-c system - presumably it performs like a 40mm lens on an aps-c, ie a fairly normal length lens.
Terms like wide angle, tele and normal are only relevant to a particular format, so a 40mm lens is a 40mm lens is a...etc. The angle of view that gets recorded is dependent on the sensor or film size. For example, a 300mm lens is normal on an 8x10, short tele on a 4x5, mid tele on a 6x7, long tele on a 35mm, and extreme tele on an APS-C sensor. It helps to visualize an image on an 8x10 ground glass, and then masking the ground glass with black paper that has windows corresponding to other format sizes cut out of the centre. Nothing about the lens or it's characteristics is changing. The only change is the angle of view, which is caused by the size of the "window" you're looking through.
One thing to be aware of though. Medium and large format lenses resolve less detail than lenses designed for APS-C are capable of, but they retain more detail when printed because they don't have to be enlarged as much.
